I made it on Win7 64bit, but it was not easy.
Installing the program was not the problem, but getting a working connect to the 2N v1.90 was quite a problem.
But as a hint, did you have installed JRE before you started the JDL installation...?
Using windows 7 I have successfully loaded JDivelog 2.16, set the driver and com port but lost on the protocol version - Auto doesn't work and I can't see on the drop down list the correct protocol.
new user of Ostc, i install Jdivelog 2.16 and diving log 5 on my win7 x64, and it s fully fonctional.
JRE is install on my system, no specific driver, and protocol version is OSTC Mk.2 Version 1.91-X,it is on the very bottom of the dropbox.
Note, i install jdivelog in c:\jdivelog not in the program files directory.
The only bug i found, is in jdivelog (n° of OSTC is not good)
