goodmorning, I have a question, with ostc 2n is possible to change a deco plan, for example if I have at 21 m. a gas change, instead 1 or 2 min. I want to insert 5 min. of deco and so for other depth...o this is a function only in DR5?
thank you very much in advance.
deco plan
PeterK
Re: deco plan
Take a look at CF55. However, be aware that there is an issue in firmware 1.90 that gives strange deco plans when using CF55>0. Should be fixed with the next FW.
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
Gucky
Re: deco plan
CF55 ist der richtige Tipp.
In den (Beta) Versionen größer V1.90 funktioniert CF55 gut für den Plan, nach dem Gaswechsel wird aber eine neue Stopzeit ohne die in CF55 festgelegte Zeit für die Wechseltiefe berechnet.
translate by google
CF55 is the right tip.
In the (beta) versions larger V1.90 CF55 works well for the plan, but after the gas exchange is a new stop time, without specified in CF55 time calculated for the change of depth.
translate by google
Gruß Gucky
