I have released a new parser written in Perl to convert OSTC.DMP files produced by libdivecomputer to UDCF format. It should work with both firmwares (1.90) but has only been tested with the old format (1.90).
It is available here. If you do not read French, get file "loogbook.zip" from there, unzip it and read file "README.txt" first.
As I already stated some times ago, my purpose is to create a logbook in PDF using pdfLaTeX.
Other Perl scripts are available at the same location, to convert .jlb files procuced by JDiveLog to UDCF format, and to convert UDCF files into LaTeX source files.
If some of you can provide me with OSTC.DMP files dumped with the new firmware (> 1.90), I'd be very grateful. I need to check my parser with both CCR dives and OC dives and I have no opportunity to dive again before september
Of course any comments, bug reports, etc., are welcome.
Best regards,
Daniel Flipo, OSTC Mk2 1610.
