Stable 1.22
Stable 1.22
Die neue 1.22 stable ist jetzt verf?gbar - damit kommen nach 2 Monaten auch die Benutzer der Stable versionen in den Genuss der neuen Funktionen.
http://www.heinrichsweikamp.net/ostc/de ... 750ABB.htm
The new 1.22 stable is now available - users of the stable releases waited two months to have access to the new functions.
http://www.heinrichsweikamp.net/ostc/en ... 750ABB.htm
Matthias Heinrichs
Matthias Heinrichs
nicolas schreyer
Re: Stable 1.22
I saw something strange tonight...
for the 5 last minutes (after the deco-stops end)in 3-4m of water,4 or 5 times, the no-deco indcation get from 160 to 0 and finish to stay on 0...until the surface mode...
did I forget to set something after to last update (from 1.21 to 1.22) ?
actual setting are:
L16-GF (30-80)
last stop on 6m
the other parameters are on default values
actual setting are:
L16-GF (30-80)
last stop on 6m
Re: Stable 1.22
I will test this during a dive today. I think the leading tissue changed several times during the ascend.
nicolas schreyer
Re: Stable 1.22
nur eine kleine Frage:
ist es normal dass die "Desat" Zeit ist k?rzer als die "no-Fly" Zeit ist??
Re: Stable 1.22
Hallo Nicolas,
Kannst Du mal schreiben was f?r Tauchg?nge mit welchen Gasen Du da gemacht hast?
Gruss,
Gruss,
nicolas schreyer
Re: Stable 1.22
Tief. 70
Dauern. 47
Gas:Tx 19/30, Nx 32 Nx 70
[IMG]http://img219.imageshack.us/img219/5263/profil689mp3.th.jpg[/IMG][IMG]http://img219.imageshack.us/images/thpix.gif[/IMG]
Dauern. 47
Re: Stable 1.22
Wenn I open the ostc_part2 workspace, a file named p2_deco_main_c_v105.c is included in the workspace althought the file in the source is p2_deco_main_c_v104.c, if i replace the 105 by the 104 it works fine but i just wanted to make sure that by doing that i really have version 1.22 and not an intermediary release.
Best Regards
Sebastien Kister
Best Regards
Sebastien Kister
Re: Stable 1.22
p2_deco_main_c_v104.c is the latest stable. I will update the sourcecode package. 105 is a beta.
Re: Stable 1.22
Hello Nicolas,
We run hundreds of such dives in the simulator, Are you really sure that the NoFly-Time was bigger then the total Desat. time? I'm afraid I can't see any issue causing this effect.
andersnasman
Re: Stable 1.22
- Running the computer with the simulator I get strange results when I try "Reset Deco data" the computer is logging 96m.
- Is it normal that the deco display (sum) only shows up to 99 minutes? Tried a dive to 100m for 15 minutes
- The behaviour of the Deco table in the OSTC is strange, a random number of stops shows 0 minutes while stops mor deep or more shallow shows the real numbers... I will try to get a profile to You and some photos asap.
Re: Stable 1.22
Deco data can only be reseted in surface mode, not during the (simulated) dive.
> 15 minutes
Yes.
Right now, the GF deco model calculates the actual deep stops based on the current saturation situation and so specific stops may not be required in terms of tissue saturation but are displayed with 0 minutes as a recommended deep stop.
> 15 minutes
Yes.
Re: Stable 1.22
I still have problem with my logbook. I can't see the profile of the last dive... With the others ther is no problem.
And I can't see them with Jdivelog. But no problem with divinglog...
Yesterday no problem.
Today the battery led is blinking without the USB plug.
And now the profile is out...
Servan
Servan
Re: Stable 1.22
Blinking battery symbol in surface or divemode means weak battery.
Re: Stable 1.22
> means weak battery.
Hello Matthias,
Thanks for your answer, but the battery symbol is full and the voltage is 4.18V
Servan
> means weak battery.
Hello Matthias,
Servan
Re: Stable 1.22
1.18 does not blink and still show the profile without troubles?
Re: Stable 1.22
1.18 is not bugging, but shows profile with problem
[img]http://nsa03.casimages.com/img/2008/12/18/mini_081218101407699717.jpg[/img]
I'll say later if the battery Led is blinking.
Thank you
Servan
Thank you
Servan
Re: Stable 1.22
I confirm, the led is not blinking with 1.18
Servan
Servan
Re: Stable 1.22
Really strange. Is anybody experiencing this problem, too?
Maybe you can test again with the 1.23 (Just released)? As for your logbook problem: Best think you can do is a "Delete all", this will re-format the entire profile memory area.
Re: Stable 1.22
With 1.22 : the Led blink twice for 4.14V and more
With 1.18 : no blink for the same voltage
OK I delete all the logbook. The problem appears after using the JDIVELOG transfert protocol ...
Servan
Servan
Re: Stable 1.22
JDiveLog does not have direct access to the profile memory, so this is most likely not the problem.
Re: Stable 1.22
I remember settings I've changed before the problem appears.
I've changed CF20 ; CF21 ; CF22
My values :
* CF20 = 1
* CF21 = 60
* CF22 = 10
Can it be the source of the problem ?
Servan
My values :
* CF20 = 1
* CF21 = 60
* CF22 = 10
Servan
