hi,
Is it possible to download all the data of a dive on a computer?
I know that is possible to use Jdivelog but only a small part of informations are present (no info about gaz switch, deco, CCR mode, gaz list, etc...)
I already try to open the jdivelod logfile with a spreadsheet soft (excel) but it doesn't work.
Thanks for yours solutions or ideas
FO
download dive data from OSTC MK2
Re: download dive data from OSTC MK2
the ostc itself contains the data. it is up to the software to provide the information though.
not sure about jdivelog, but kenozooid ( the software i am developing shows gas switches, setpoint changes, deco ceiling, ascent/descent speed, etc.
some screenshots are at
seems like some of the links were eaten by the forum engine :/
webpage: wrobell.it-zone.org/kenozooid/
screenshots: freecode.com/projects/kenozooid
Hi, Diving Log does download almost all relevant data.
Tanks wrobell,
kenozooid look like very interesting but this solution is not compatible with windows OS
thanks
thanks
FO Wrote:
> Tanks wrobell,
Then you could have a look at my stuff (Perl-based) here:daniel.flipo.free.fr/plongee
If you don't read French, just download logbook.zip, unzip it and read file README.txt.
Best,
Daniel
> Tanks wrobell,
Best,
Daniel
FO Wrote:
> Tanks wrobell,
indeed, i will probably will not have time to create windows installers but if someone steps in... and there is as well issue with one of the libraries i am using as it does not support windows at the moment (but fortunately there is some progress in this department).
on top of that i am planning no GUI for kenozooid, so it is another barrier for people scared of command line (but on other side i am considering some voice based system).
w
> Tanks wrobell,
w
