OSTC MK2 does not work anymore after trying to download V2.20
Martijn
Post by Martijn »
Dear..
I tried to update my OSTC MK2 but when it started the OSTC MK2 shuted off and it does not do anything anymore. Cannot turn it on, and also not light is blincking (also not when connected to computer.
What can I do? Is there a possibility to reset or an other solution?
Martijn
Re: OSTC MK2 does not work anymore after trying to download V2.20
Post by Bardass »
Do you try the reset with a magnet ?
Martijn
Post by Martijn »
How do you reset with a magnet?
Martijn
Martijn
Post by Martijn »
Still completely dead.
If I connect the OSTC to the pc it connects but says PIC not found.
The OSTCMK2 does not give any sign of live..
Any ideas anyone?
JeanDo
Post by JeanDo »
1. What was the firmware version BEFORE you upgrade ?
2. What version of the bootloader do you use ?
martijn
Post by martijn »
I used the latest firmware 2.01 I think. and I tryied it with the latest bootloader.
I always update with the latest firmware and never had any problems with this.
Martijn
JeanDo
Post by JeanDo »
For the reprogram-while-magnet-reboot trick, you need to use the v1 bootloader (or just change the .ini configuration file to set speed to 19200, instead of 115200).
Hope this helps,
