Bungee for OSTC
Re: Bungee for OSTC
Just push the metal pins with an other pin... but be careful.
I made it this way and it worked perfectly.
\Andreas
\Andreas
Re: Bungee for OSTC
Can I ask you what is that thing on the right? BU bungee? Otherwise your bungee looks doable
Maybe after couple of months, DeepSeaSupply makes a molded bungee case for OSTC also.
Re: Bungee for OSTC
> bungee?
The bungee on the right is here to secure the OSTC in case of break of the main bungee.
If you use 2 bungees instead of one like me, you don't need this one.
> bungee?
