there is a little discrepancy in the english and german description of CF24
The english description talks about a ppO2 Sensor value.
The german about a ppO2 Value.
So is this a value based on a sensor or the calculated value according to the Gas and depth?
Personally i believe the german version
www.heinrichsweikamp.net/#/en/ostc_2n/l ... functions/
CF24:ppO2 sensor sampling divisor
This value sets how often the ppO2 sensor data (dependent on the sampling rate CF20) should be stored in the dive profile.
Recommend range: 2 ... 10 (Every 2...10 depth samples, the ppO2 sensor data is stored additionally)
Default setting: 0 (The ppO2 sensor data is not stored)
Example 1: CF20=10 CF24 = 2 - Every ten seconds, the depth is stored. The ppO2 sensor data is stored every 20 seconds additionally
Example 2: CF20=1 CF24 = 60 - Every second, the depth is stored. The ppO2 sensor data is stored every minute additionally
Example 3: CF24 = 0 - The ppO2 sensor data is not stored as all.
and
www.heinrichsweikamp.net/#/de/ostc_2n/l ... functions/
CF24:Divisor für Speicherung des ppO2
Dieser Wert gibt an in welchem Verhältnis zur Abtastrate (CF20) der ppO2 im Profilspeicher des OSTC gespeichert werden sollen
Empfohlener Wertebereich:2 ... 15 (Alle 2...15 Tiefensamples auch den ppO2 abspeichern)
Grundeinstellung: 0 (Der ppO2 wird nicht gespeichert)
Beispiel: CF20 = 10 CF24 = 2 - Alle zehn Sekunden wird die Tiefe, alle 20 Sekunden wird auch der ppO2 abgespeichert
Diese Custom Funktion hat beim alten OSTC1 keine oder eine andere Bedeutung!
