We've moved! - Wir sind umgezogen!
Das Forum läuft nun auf unserem eigenen Server und sollte wesentlich schneller laufen. Außerdem haben wir die Suchfunktion (endlich) verbessert. Alte Links auf andere Beiträge werden wir in den nächsten Tagen auf die neue Domain forum.heinrichsweikamp.com "umbiegen".
The forum now runs on our own server and should be much faster now. We also enhanced the search option (finally). Old links to other articles in the forum will be changed from us to fit the new domain forum.heinrichsweikamp.com in the next days.
Re: We've moved! - Wir sind umgezogen!
@HW, Matthias
Ich hatte schon fast Entzugserscheinungen!
Vielen Dank für all eure Arbeit.
And there is still no Like button....
Would be nice to have a redirect from the old forum location to the new one for the next weeks...
+1
A permanent redirect link to the new website would allow to find you on google...
Don't worry - heinrichsweikamp.net will be redirected to .com in a few hours. It just takes some time to update all DNS servers...
Hi again,
I think it is not a problem of DNS and update. Both
Trouble is that:
http://87.106.57.34/
it failing...
My raw guess is that in your HTTP server configuration is bad. You probably have a filter on incoming name, and did not add any aliases (87.106.57.34, old name, etc).
Also, a 'HTTP permanent redirect' would make sure all the google searches are correctly and rapidly changed to the new address, including changing www.xxx.net/forum to forum.xxx.com
- nslookup www.heinrichsweikamp.com
nslookup www.heinrichsweikamp.net
Trouble is that:
it failing...
30x redirect is also essential if you care about SEO (which I'd strongly suggest)
We actually don't care much about SEO, Facebook or +1, but this does not belong here.
.net is now working again. I'll check the redirects to .com on Monday. Since weather is fine -> diving...
cheers,
cheers,
For me, better than +1 or Facebook, it would be nice to add rss feeds to this forum.
Apparently, it is possible with phorum ....
Jean-Phi
Jean-Phi
OSTC 2N #2755
