scubatinoo:
>Following your arguments we can turn our OSTC into simple
>OLED bottom timers, because we don't need any reminder for deco
>stopps (you can write them on a table), and we don't need
>a hint for a gas switch, because we know when to switch gases,
>and so on...
Yes,we can turn the OSTC into bottom timer,we have Gauge mode...but I prefer OC GF10/80 for tech and OC Buhlmann set to roughly match Suunto's predictions for NDL dives,with switch hints enabled.Written backup in wetnotes plus ratio deco,but often quite a change of plan is unavoidable.Then it is up to experience to merge RD with Buhlmann,worst case being longer shallow stops from OSTC.
Comparing multigas multiswitch dives' complex stops to the simpliest of calculations(adding 3 to the current number) at the end of a NDL dive at the depth of 5 metres is a little simplistic imho.
So I am far from suggesting to remove any of the functions already applied,I simply value the somehow limited amount of CFs and would like to see them populated by more useful options,like real-time depth curve in divemode,or ability to set depths in gaslist for descent/ascent separately,or to toggle the "death" of OSTC in 130m off(assuming RESPONSIBILITY for doing so),just a few.
Many of us use OSTC for all dives,and it supports "no deco" dives to the same extent as "deco" ones.If a stop is required,it is displayed.Pushing to the limits of the table will result in having stop(s) displayed on OSTC,tested.Same for tables,safety stop is required only in similar cases.
And the "regular"safety stop we always do before final ascent - do we really need a reminder of what we do on every dive?
Although OSTC can be used for recreational dives,it was not primarily designed to do so,still all the necessary(and more) info is there,and in my opinion asking for safety stop always displayed is like insisting on coffeecup holder inside cockpit of F1 monopost.
This request is about something already there,check the above mentioned sequence,it takes less than 2 seconds.
Quote from HW homepage:
>What this OSTC 2N dive computer is not:
>Competition for cheap mass products for the occasional diver.
>What this OSTC 2N dive computer is:
>An experimental platform for all experienced divers who are interested in the >theory of diving and who value maximum transparency and individual adaptabily .
>There are already several high-performance dive computers on the market-- not >quite a dime a dozen, but enough to give users a choice of products.
Chill out,buy stuff that suits your needs
Richard
