ich w?rde gerne wissen ob man mit dem OSTC an die Ergebnisse des unten angeh?ngten Plans rankommt.
(auf +- X Minuten und Meter kommt es mir nicht an, sollte nur ann?hernd m?glich sein).
Dann w?re der OSTC auch interessant f?r mich.
W?re nett wenn Ihr mir mal einen OSTC Plan posten k?nntet.
Decompression model: VPM - B/E
DIVE PLAN
Surface interval = 5 day 0 hr 0 min.
Elevation = 0m
Conservatism = + 3
Dec to 30m (2) Triox 35/25 13m/min descent.
Dec to 80m (6) Trimix 14/55 13m/min descent.
Level 80m 13:51 (20) Trimix 14/55 1.25 ppO2, 25m ead, 30m end
Asc to 57m (22) Trimix 14/55 -10m/min ascent.
Stop at 57m 0:42 (23) Trimix 14/55 0.93 ppO2, 16m ead, 20m end
Stop at 54m 1:00 (24) Trimix 14/55 0.89 ppO2, 15m ead, 19m end
Stop at 51m 1:00 (25) Trimix 14/55 0.85 ppO2, 14m ead, 17m end
Stop at 48m 1:00 (26) Trimix 14/55 0.81 ppO2, 13m ead, 16m end
Stop at 45m 1:00 (27) Trimix 14/55 0.77 ppO2, 12m ead, 15m end
Stop at 42m 1:00 (28) Trimix 14/55 0.72 ppO2, 10m ead, 13m end
Stop at 39m 2:00 (30) Trimix 14/55 0.68 ppO2, 9m ead, 12m end
Stop at 36m 1:00 (31) Triox 35/25 1.60 ppO2, 13m ead, 24m end
Stop at 33m 1:00 (32) Triox 35/25 1.50 ppO2, 12m ead, 22m end
Stop at 30m 2:00 (34) Triox 35/25 1.39 ppO2, 10m ead, 20m end
Stop at 27m 2:00 (36) Triox 35/25 1.29 ppO2, 9m ead, 18m end
Stop at 24m 2:00 (38) Triox 35/25 1.18 ppO2, 7m ead, 15m end
Stop at 21m 3:00 (41) Nitrox 50 1.54 ppO2, 10m ead
Stop at 18m 3:00 (44) Nitrox 50 1.39 ppO2, 8m ead
Stop at 15m 4:00 (48) Nitrox 50 1.24 ppO2, 6m ead
Stop at 12m 6:00 (54) Nitrox 50 1.10 ppO2, 4m ead
Stop at 9m 8:00 (62) Nitrox 50 0.95 ppO2, 2m ead
Stop at 6m 30:00 (92) Nitrox 99 1.58 ppO2, 0m ead
Surface (92) Nitrox 99 -10m/min ascent.
Vergleich Tauchplan VPM und OSTC
Re: Vergleich Tauchplan VPM und OSTC
I guess this will do:
MV-Plan 1.5
Settings: GF=10-85 ppH2O=0.627 msw
DESC: 80m for 04:00 [ 4] on Trimix 14/55, SP: 0,0, END: 25m
DIVE: 80m for 16:00 [ 20] on Trimix 14/55, SP: 0,0, END: 25m
ASC : 54m for 02:36 [ 23] on Trimix 14/55, SP: 0,0, END: 15m
DECO: 54m for 00:23 [ 23] on Trimix 14/55, SP: 0,0, END: 15m M-Value: 61% [02], GF: 14%
DECO: 51m for 01:00 [ 24] on Trimix 14/55, SP: 0,0, END: 14m M-Value: 64% [02], GF: 18%
DECO: 48m for 01:00 [ 25] on Trimix 14/55, SP: 0,0, END: 13m M-Value: 66% [03], GF: 22%
DECO: 45m for 01:00 [ 26] on Trimix 14/55, SP: 0,0, END: 12m M-Value: 68% [03], GF: 27%
DECO: 42m for 01:00 [ 27] on Trimix 14/55, SP: 0,0, END: 10m M-Value: 71% [03], GF: 31%
DECO: 39m for 01:00 [ 28] on Trimix 14/55, SP: 0,0, END: 9m M-Value: 73% [03], GF: 35%
DECO: 36m for 02:00 [ 30] on Trimix 14/55, SP: 0,0, END: 8m M-Value: 76% [04], GF: 39%
DECO: 33m for 01:00 [ 31] on Trimix 35/25, SP: 0,0, END: 12m M-Value: 77% [04], GF: 43%
DECO: 30m for 01:00 [ 32] on Trimix 35/25, SP: 0,0, END: 10m M-Value: 78% [04], GF: 48%
DECO: 27m for 02:00 [ 34] on Trimix 35/25, SP: 0,0, END: 9m M-Value: 81% [04], GF: 52%
DECO: 24m for 02:00 [ 36] on Trimix 35/25, SP: 0,0, END: 7m M-Value: 82% [05], GF: 56%
DECO: 21m for 03:00 [ 39] on Nitrox 50, SP: 0,0, END: 10m M-Value: 85% [05], GF: 60%
DECO: 18m for 03:00 [ 42] on Nitrox 50, SP: 0,0, END: 8m M-Value: 85% [06], GF: 64%
DECO: 15m for 03:00 [ 45] on Nitrox 50, SP: 0,0, END: 6m M-Value: 86% [06], GF: 68%
DECO: 12m for 06:00 [ 51] on Nitrox 50, SP: 0,0, END: 4m M-Value: 90% [07], GF: 73%
DECO: 9m for 09:00 [ 60] on Nitrox 50, SP: 0,0, END: 2m M-Value: 90% [07], GF: 77%
DECO: 6m for 31:00 [ 91] on Oxygen, SP: 0,0, END: 0m M-Value: 92% [08], GF: 85%
Ok, it's not from an actual OSTC, but MV log which uses the same algorithm, so the OSTC will do the same. Just enter GF low 10 GF high 85 and You get the result above which almost fits the VPM B/E +3 profile exactly.
MV-Plan 1.5
Sound good.
Can anybody please confirm this with te OSTC.
When looking to the online manual I am not sure if it is possible to set GF LOW to 10% (recommended range 20-20%)
Hi, you can set the low GF on the OSTC as low as 1 ( one ).
Thomas Wrote:
> sorry 20-30%
Have not had time to try it in the OSTC yet, but setting GF low to 20 should have Your deco start at around 48m (1 bar less than what GF LO=10 would do). Changing the High level to 80 instead lands you at 92min runtime again. We dived a lot of 10/80, as well as 20/85. I have friends that always dives 10/90 and have had no problems with that either, but as we all know that depends on your current condition.
Settings: GF=20-80 ppH2O=0.627 msw
ASC : 48m for 03:12 [ 23] on Trimix 14/55, SP: 0,0, END: 13m
DECO: 48m for 00:47 [ 24] on Trimix 14/55, SP: 0,0, END: 13m M-Value: 67% [02], GF: 24%
DECO: 45m for 01:00 [ 25] on Trimix 14/55, SP: 0,0, END: 12m M-Value: 69% [03], GF: 27%
DECO: 42m for 01:00 [ 26] on Trimix 14/55, SP: 0,0, END: 10m M-Value: 71% [03], GF: 31%
DECO: 39m for 01:00 [ 27] on Trimix 14/55, SP: 0,0, END: 9m M-Value: 74% [03], GF: 35%
DECO: 36m for 02:00 [ 29] on Trimix 14/55, SP: 0,0, END: 8m M-Value: 76% [04], GF: 39%
DECO: 33m for 01:00 [ 30] on Trimix 35/25, SP: 0,0, END: 12m M-Value: 77% [04], GF: 43%
DECO: 30m for 02:00 [ 32] on Trimix 35/25, SP: 0,0, END: 10m M-Value: 79% [04], GF: 46%
DECO: 27m for 01:00 [ 33] on Trimix 35/25, SP: 0,0, END: 9m M-Value: 79% [05], GF: 50%
DECO: 24m for 03:00 [ 36] on Trimix 35/25, SP: 0,0, END: 7m M-Value: 83% [05], GF: 54%
DECO: 21m for 02:00 [ 38] on Nitrox 50, SP: 0,0, END: 10m M-Value: 83% [05], GF: 57%
DECO: 18m for 03:00 [ 41] on Nitrox 50, SP: 0,0, END: 8m M-Value: 85% [06], GF: 61%
DECO: 15m for 04:00 [ 45] on Nitrox 50, SP: 0,0, END: 6m M-Value: 86% [06], GF: 65%
DECO: 12m for 06:00 [ 51] on Nitrox 50, SP: 0,0, END: 4m M-Value: 88% [07], GF: 69%
DECO: 9m for 09:00 [ 60] on Nitrox 50, SP: 0,0, END: 2m M-Value: 89% [07], GF: 73%
DECO: 6m for 32:00 [ 92] on Oxygen, SP: 0,0, END: 0m M-Value: 91% [08], GF: 80%
> sorry 20-30%
