I think I've made a bit of a boo boo. I was trying to update the Beta 2.25 but think I have reloaded v2.21. I've not done it before so this was a first attempt. Now i have the bootloader v2 saying 'write ok at 10:37, time 47.266 sec.
The 2N is still attached and has the main screen up showing V2.21 but under the mbar reading is a counter (currently at 47.30mins and going up).
Is that the download complete? Can I unplug it?
Sorry if it seems a dumb question but I don't want to cause myself any more problems.
I'll work out how to download the Beta at a later date I think.
Jerry.
Update problem
Update problem
Re: Update problem
If there is "2.25 beta" in the first line the update is done. Just reset your time and date and you're ready.
Re: Update problem
Hi, no it does not say 2.25beta but that's because I didn't do it correctly. I followed the instruction to update the stable so I think I have reloaded the v2.21. Is it ok to disconnect?
Jerry.
Jerry.
Re: Update problem
With "Web Download" you always get the latest stable, so yes, you re-installed the 2.21.
When you see the surface screen again ou can disconnect.
