New firmware 2.27beta
In der 2.26beta haben wir das Verhalten des Safety Stops nochmal geändert - damit ist das Thema für uns aber abgeschlossen. Wer andere Zeiten oder Tiefen möchte, kann das relativ einfach im Code ändern.
http://www.heinrichsweikamp.com/#/de/ostc_2n/firmware/
In the new 2.26beta we have adjusted the safety stop behaviour as discussed here. There are no plans to make this configurable via CFs. If someone wants other depths or durations please change this in the code and compile your own hex file.
http://www.heinrichsweikamp.com/#/en/ostc_2n/firmware/
Re: New firmware 2.26beta
Thanks for your efforts!
How is the behavior now?
Any plans on when you'll release the next stable firmware?
:S
DiverM
This is exactly why I like OpenSource so much!
Want something special? DIY!
OSTC 2N #4807
Custom Functions documentation is up to date too.
Die Custom Functions Dokumentation ist auch auf dem neuesten Stand.
Regards/Grüße
Regards/Grüße
Home: http://www.angermayr.eu
email: ostctools@angermayr.eu
fishwithlungs
anybody tried it yet?
My 2N is not responding after firmware update.
Done through JDivelog,everything went fine,confirmation dialog notified of successful writing of firmware.Since then half an hour passed,computer remains unresponsive with black screen.
(Yesterday I updated Seawooch to v2.25+,that was a mess in all CFs with text covering each other and leaving other places empty,downgraded back to 2.20+.)
Thought HW's version would work better,but how do I go back to latest stable with unresponsive unit?(Didn't try the magnet method yet,as there are some reservations regarding that.)
USB serial port is COM16,bootloader v2 cannot find PIC.Updating via JDivelog doesn't work since I can't press reset on non responding unit.
I have upgraded OSTC Mk.2 through every version starting with v1.5,so definitely I should know what I am doing.
Any ideas?
Richard
Any ideas?
Richard
A non-responding unit after the update showed successful is unlikely. Just try it again - and now trigger the magnet reset instead of using the reset menu. Note, this will only work with the bootloader v1 or Jdivelog since the bootloader then uses 19200baud instead of the 115200baud when using the bootloader v2.
fishwithlungs
Matthias,lightning fast answer!
Either the magnet is not strong enough or ...I hope not!
Where do i find strong magnet in Egypt remains a question...
Update showed success in JDivelog,usually there's slight delay before the screen comes up on 2N,or press of any button does it.Not this time.
Richard
Richard
Hi there,
here with 2.26 over 2.25 (german version) no problem.
OSTCTools, read, write, accessing profile data no problem.
Savety stop works in simulator.
> hope not!
> question...
Normal Magnet should work too. Just make sure that you have
plugged in the USB cable and all together hangs on your computer...
> hope not!
> question...
- Show 3min safety stop for no-deco dives>10m
- show stop between 5 and 3m
- remove stop above 3m
- reset stop when descending to 10 again
There is a section "Safety stop parameters" in the definitions.asm where these thresholds can be changed with 1mbar resolution.
DiverM
Having said this, I downloaded the source, the IDE, even managed to compile a Hex file without any errors. But when I load that Hex file onto my OSTC, it goes black.
Programming goes fine:
Connected to \\.\COM1 at 115200
HEX: 1 min old, INHX32,18Fcode+cfg, total=82702 bytes.
Searching for PIC ...
Found:18F 4685
Reading HEX file... , Writing flash...
WRITE OK at 18:50, time:41.396 sec
But after this the OSTC goes black. (Reloading the last stable firmware is possible with the magnetic reset and bootloader V1)
I'm compiling Beta V2.27 source. Only changed the safety-stop depths, and after very careful review (as I will only be using OC mode with GF) changed the Beta flag to 0.
OSTC Hardware: 2N Ser# 4807
Found:18F 4685
OSTC 2N #4807
fishwithlungs
Matthias,
this is the output of BLD v1.0
Bootloader for HeinrichsWeikamp OSTC,
based on TinyBootLoader, v.1.9.5 written by claudiu.chiculita@ugal.ro
http://www.etc.ugal.ro/cchiculita/softw ... loader.htm
Connected to \\.\COM16 at 19200
HEX: 6 hours old, INHX32,18Fcode+cfg, total=82684 bytes.
Found:18F 4685
WRITE OK at 18:50, time:42.291 sec
but the comp remains black after 20 mins.
Gonna give it another try.
Edit: output now
ERROR!
Richard
Edit 2: JDivelog : Success!Writing of firmware finished.
2N remains black.
Found:18F 4685
Edit: output now
ERROR!
Richard
2N remains black.
The log looks like a perfect update. From here, hard to tell what's happening there. You can try with an older version but this could also be a hardware issue of some kind.
DiverM
Attached, my custom hex file, and the changed definitions.asm
Maybe you can do a comparison with a hex you compile? could be some ide configuration issue as well. (although I did use the sample workspace included in the source)
OSTC 2N #4807
Can you first test if the original HEX file from our firmware section works?
DiverM
..\mk2_v226-beta.hex
HEX: 0 min old, INHX32,18Fcode+cfg, total=82684 bytes.
Found:18F 4685
WRITE OK at 19:28, time:43.187 sec
Result: Black screen
Found:18F 4685
OSTC 2N #4807
Ok, downgrade to the 2.21 (or 2.25beta, attached) using the bootloader v1 trick above. Maybe I can check this issue with the 2.26beta tomorrow morning...
fishwithlungs
going back to 2.25 for now.That did the trick,thank you.
Richard
Richard
DiverM
..\mk2_v225-beta.hex
Connected to \\.\COM1 at 19200
HEX: 11 days old, INHX32,18Fcode+cfg, total=82678 bytes.
Found:18F 4685
WRITE OK at 20:30, time:23.775 sec
Result: Functional.
Feel free to ask me to test any other firmwares in resolving this issue, or for any future issues regarding firmware and hardware.
Found:18F 4685
Result: Functional.
OSTC 2N #4807
Smiler1968
I've uploaded to 2.26 beta. No obvious problems and works ok in a simulated dive.
Jerry.
Jerry.
cparsons
Same for me - 2.26 beta seems to work fine, and the safety stop countdown is behaving as intended in the simulator.
Chris Parsons
OSTC 2n #2516
Chris Parsons
OSTC 2n #2516
Re: New firmware 2.27beta
I think the problem only exists if the 2.25beta was NOT installed before. Should be fine now with the 2.27beta I just uploaded.
DiverM
Problem solved then! I'll test it on monday, today and tomorrow I'm off diving.
After tomorrow next dive is planned Wednesday or Thursday.
Martijn
Martijn
OSTC 2N #4807
nakatomi
Sorry to bring this up again, but in my opinion the safety stop behavior should be changed. Most agencies, virtually all of them including several technical agencies, recommend a stop depth of 5 meters and it makes absolute sense to also support this in the device.
The way it is implemented now, with a countdown only running in a window of 3-5 meters, one would have to always stay shallower than 5m to complete the stop. That does not make sense.
Making it 3-6 meters makes more sense, or if that is not wanted, 4-6 meters should work nicely. Stops at 3m are nowadays very unconventional anyway...
Oliver
OSTC Mk2 1830
OSTC Mk2 1830
