Unnecessary charging?
Posted: 05 Jan 2013, 20:22
Hi everybody,
I am still playing with my new OSTC 2n and maybe I should RTFM a bit more but I could not find where it says how the charging algorithm works.
My problem:
-I connected a new OSTC stating it had a pretty new battery (2 cycles) which was almost completely charged to my computer (this was to check drives and connectivity to OSTC planner);
-Battery symbol turned yellow (that was expectedB)-)
-after disconnecting I get 3 cycles on the battery ..... (that was not expected::o)
Now since I like to download often (and maybe play with colors and parameters) I am afraid that I will load a cycle per dive or even more, maybe stressing the battery (is that so?:S).
Is the charging controlled by software? If so would it be possible of feasible set a minimum level of discharge before charging? Possibly the level would be configurable so for me diving close to home and often I can wait 30% but when leaving for a trip, no matter what I would like to give it a full charge ....
Fabio
My problem:
Fabio
