OSTC 2N Problem: no deep
luthien
Post by luthien »
Hello, first I apologize for my bad English.
Today I started the dive and the OSTC 2n showed all the data except for the depth. Having the second computer I continued the dive course, maximum depth 10 meters. After 6 minutes, the OSTC 2n is turned off and then turned on (an automatic reset?) and it started to work properly.
The dive logbook has stored at 0 meters 5 minutes as first dive and a second dive time and depth correct when it restarted. Firmware 2.50. What has happened? Thanks.
Italiano:
Oggi ho iniziato l'immersione e l'ostc 2n mostrava tutti i dati tranne la profondità. Avendo il secondo computer ho continuato l'immersione di corso, massima profondità 10 metri. Dopo circa 6 minuti l'ostc 2n si è spento e poi acceso da solo (un reset automatico?) ed ha iniziato a funzionare correttamente. Il logbook ha memorizzato un'immersione a 0 metri di 5 minuti come prima immersione e una seconda immersione con tempo e profondità corretti quando si è riavviato. Firmware 2.50. Cosa è successo? Grazie
Re: OSTC 2N Problem: no deep
very unusual. Can you upload the dive here? Try Divinglog http://www.divinglog.de or e.g. the OSTCTools http://www.angermayr.net/download/ostctools.htm
luthien
Post by luthien »
Here is the file, I hope it's what you wanted. thanks
Sorry, that's no logbook file. Which software did you use?
luthien
Post by luthien »
Diving Log 5.08. How can i save and upload the file?
luthien
Post by luthien »
In excel are good?
Divinglog files end with .mdb
So, there's the logbook.mdb somewhere.
luthien
Post by luthien »
logbbok.mdb is 2316 KB, I can not upload it ... how can I load it?
Email it to me: info@heinrichsweikamp.com If you delete all dives except the two with the issues it will get smaller.
