I set up some gases with changing depths - Air as default and Nx50 with 21m; O2 with 6m.
Then I go in plan deco menue, and enter for example 31 minutes for bottom time and 40m for max depth. OSTC3 calculates deco.
If I don't push any button, the computer makes a reset after a while and my configured gases are gone. btw. on first reset it changed from OC to CCR, as I tried to reproduce this reset, it lost the changing depths of the gases.
OSTC3 fw 0.91 Bug or Feature?
Re: OSTC3 fw 0.91 Bug or Feature?
This was a bug, the current configuration was not saved into the non-volatile memory when the timeout occurred in the decoplanner page.
Has been fixed with the 0.93 available here: http://www.heinrichsweikamp.com/?id=162&version=en
