BO-gaslist in CCR-mode
boefst
Post by boefst »
Hi.
Excellent update V2.70.
Regarding the following enhancements,
“NEW: 5 Gases extra for CC”
“NEW: Cursor is in front of the better gas automatically”
Is it possible to get the similar feature also in BO-gaslist in CCR-mode?
I think it would be nice if the the curser was automatically positioned in front of the First & Active BO-gas, instead of G1. That way I never need to change the gas order in Gas Setup-meny to achieve the simple LEFT-RIGHT-RIGHT-RIGHT-RIGHT-sequence to bail out.
Since I, depending on the dive to be made, use different BO-gas, all I have to do before the dive is to mark the correct BO-gas as First Gas.
Re: BO-gaslist in CCR-mode
That's a good idea (And easy to implement). Attached is a beta doing exactly this (You can always revert to the latest stable without loosing any dive data).
boefst
Post by boefst »
Thanks a lot Matthias!
boefst
Post by boefst »
Nicely implemented in 2.80! Works exactly as I hoped. Thanks!
Just a small bug...
On the "Home Screen" in surface mode, only Gas 1 is displayed, even if that gas is not set as active at all...
As an example, I have this setting in my Gas List:
G1:TX 15/50 G2:NX 50 G3:O2 100 and G4: AIR
For a shallow dive I don't carry any DECO-gas and I use AIR as BailOut.
In the Gas Setup I mark G4 as First Gas and the only Active gas. Still G1:15/50 is displayed in surface mode.
/anders
Fixed in the next 1.81, use G1 as your first bailout if you need this feature.
G2-G5 are shown separately on the next page.
