OSTC2C ACTIV GAZ COLOR PROBLEM
Squalou
Post by Squalou »
Hello divers,
I bought an OSTC2C. I update it with last firmware.
Before this update and after this update : the problem is the same.
I check comparing with OSTC 2N which is ok.
when I have 3 active gaz, the first gaz and active gaz is written in white color.
the 2 other gaz , activ , are staying in the "inactive color" ;
I tried and tried, nothing to do.:(
on OSTC 2N the 3 activ gaz are in the same color "activ" white, and inactiv gaz in the inactive color . I can not have the same on the OSCT 2C ,
can you help me ?
have nice dives:)
Squalou from France
How to change also the name in ?
Re: OSTC2C ACTIV GAZ COLOR PROBLEM
Mk.2, 2N and 2C behave 1:1 with the same firmware. So, this must be an issue with your gas configuration. Maybe you haven't setup a change depth?
Custom text can be edited with a number of PC tools, e.g. Divinglog (www.divinglog.de)
Squalou
Post by Squalou »
the set up of gaz are identical to the other ostc 2n I use. Depth also.
So what can I do ?
Check CF64.
Post by Bardass »
sqalou > call me 0625176122
Squalou
Post by Squalou »
i already check 64, I put it in pink. Less colors in ostc 2c than 2n.
Ok bardarss, call you at the end of afternoon, thanks
Squalou
Re: OSTC2C ACTIV GAZ COLOR PROBLEM after flashing last firmware
Post by Squalou »
A friend of mine has the same problem after flashing the latest firmware for color of activ gaz, and for simulation (do not consider the other gaz activ in simulation)
Squalou
Post by Squalou »
I check again, Bardass thanks, only depth by default was correct.
now all is ok.
I have to resolve the connection to JLDIVE now.
