I had some strange behaviour of my deco on my ostc 2n. First dive after firmware update I get into deco 1mn/3m which sound normal but then it adds 1mn/6m and 1mn/9m and finally 1mn/9m. All those deco stops disappeared whith a slow ascent but then 3mn/3m finally stayed ?!? I run OC zh-l16 90/110
2nd dive. I decide to simulate 20mn/50m give approx. 4mn/9m and 34mn/6m with a nitrox 30 and a last stop set at 6 meter. Everything went fine until I get into deco. I get over my deco limit, so it turns red to notify and to stop countdown but at the same time it turns into 71mn deco instead of the previous 34mn!!!
Surprised I continue my deco by going a little bit down and after a while I retry the experience to make sure. Again deco turns red and suddenly went to 51mn!!!
Does anyone had the same problem?
By the way I can't get my CF41 normal, it's shows "unused" but with default and value accessible. And that even after downgrading back to 2.50 before updating again !
I'm now worried having an OSTC with "random" deco display...
