OSTC 2n button issue
Vincent Kessler
Post by Vincent Kessler »
Hi fellow OSTC divers,
my OSTC2n is now nearly 2 years old and has served on 36 dives within that time.
On the last two dives i was nearly unable to switch my gas at 21m because the right
button didn't react while the left one was ok. After hammering that right button a
minute long it finally worked on both dives.
After the first failed dive i updated firmware from 2.50 to 2.70 without seeing a
difference which should rule out any software related issues.
To rule out temperature issues i put the OSTC in the cooler to get it down to 4°C
but was not able to reproduce the issue by doing that.
So i assume this is a pressure related issue.
Did anyone besides me ever encounter that problem?
Dive profile was 56m with approx 20 minutes bottom time each. (4°C at bottom, 18°C at surface)
Vincent
Vincent Kessler
Re: OSTC 2n button issue
I should add that the next gas switch at a depth of 6m was flawless on both dives. My feeling is that the button was usable again shortly after ascending some more after the 21m gas switch.
