TTS time
DiveJunkie
TTS time
Post by DiveJunkie »
Hello OSTC divers,
I have a question about the TTS time in my OSTC 2N.
In the manual the explanation of the TTS is the total sum of the deco time. (TTS: Summe aller Decostops page 33)
In simulation:
L16-GF OC V2.70
CF11 120%
CF12 80%
let’s say 11 minutes and 54 meter, G1: 21/0.
Results in.
18M 1’
15M 1’
12M 2’
9M 2’
6M 2’
4M 10’
TTS: 25’
The total sum of decotime is 18 minutes, then what are the remaining 7 minutes.
it must have something to do with the descent time.
But from 54 to 18 meters 7 minutes is too long, so what else is in that time?
Kind regards,
Dive Junkie..
Dive Now Work Later
Re: TTS time
Post by Bardass »
Two things :
1 - don't forget time between each deco stop, almost 20s for each and 1 minute between last deco stop and surface
TTS include deco time + time to reach surface at 10m/mn
2 - CF11 and CF12 have nothing to do with L16-GF algorithm
Re: TTS time
Hi Junkie,
you are refering to the ascent time ( Aufstiegszeit ), not to the descent time ( Abstiegszeit ).
And you have to consider the ascent from 54 meters to the surface, not only to the first stop.
Your total ascent time from 54 meters to the surface with a ascent speed of 8 meters per minute results in 6,75 minutes.
Thats your 7 minutes difference from 18 minutes deco time to 25 minutes TTS.
Reiner
DiveJunkie
Re: TTS time
Thanx Bardass and Reiner,
It is a clear to me now, do you know of the 8 meters per minute in simulation fixed or also a custom function?
Re: TTS time
Post by Bardass »
It´s 10m/mn and not 8
It´s not à custom function, due to Buhlmann algorithm
Re: TTS time
TTS is the sum of
deco time
+10m/min (rounded to the next full minute)
+1min between 3m and 0m
Re: TTS time
What's about if Last Stop is set to 6m?
Re: TTS time
No difference here. TTS=Ascend time+Deco Time.
Re: TTS time
Yes, but
+1min only between 3m and 0m?
or
+1min between 6m and 0m?
or
+2min between 6m and 0m?
Re: TTS time
Yes. +1min between 3m and 0m.
