USB Charger Specifications
which are the correct values in terms of VDC/mAh for the proper charging of my OSTC 2N battery?
Thank you.
Roberto
Thank you.
Roberto
OSTC2N -- #5956 -- FW 3.13 EN
Re: USB Charger Specifications
5 VDC which is standard for all USB chargers.
I believe 500 mAh is ok, at least mine is charging well with 500 mAh.
Reiner
Reiner
My OSTC charges the best with this cheap cable: http://r.ebay.com/uIfqzf either on any USB-Charger or on PC/Mac. Somehow this Micro-USB connection fits perfectly into the USB-Port of my OSTC and the flashing light effect looks just great >:D<
Thank you, guys!
Go diving, always!
AwanaDive
Go diving, always!
AwanaDive
If it's a new 2C, a 5W DCP compatible USB charger is recommended (As any quality brand chargers are). Ultra crappy "less then 1 EUR" chargers may not work.
Does it work with the Apple USB charger ? they have a higher power like 1A
Titus
Titus
Titus
The higher the better, provided it is a 5 Volt USB standard charger.
Apple USB Charger (at least for iPhone 5) is 5V / 1A. So good for OSTC ?
Can some one from HW confirm ?
Titus
Titus
Titus
Works fine for OSTC 2N or OSTC 2C.
