USB Charger Specifications
Posted: 12 May 2014, 21:04
by awanadive
which are the correct values in terms of VDC/mAh for the proper charging of my OSTC 2N battery?
Thank you.
Roberto
Re: USB Charger Specifications
Posted: 13 May 2014, 21:47
by sailor
5 VDC which is standard for all USB chargers.
I believe 500 mAh is ok, at least mine is charging well with 500 mAh.
Posted: 14 May 2014, 08:09
by scubatinoo
My OSTC charges the best with this cheap cable:
http://r.ebay.com/uIfqzf either on any USB-Charger or on PC/Mac. Somehow this Micro-USB connection fits perfectly into the USB-Port of my OSTC and the flashing light effect looks just great >:D<
Posted: 16 May 2014, 17:44
by awanadive
Thank you, guys!
Go diving, always!
AwanaDive
Posted: 19 May 2014, 15:45
If it's a new 2C, a 5W DCP compatible USB charger is recommended (As any quality brand chargers are). Ultra crappy "less then 1 EUR" chargers may not work.
Posted: 19 Jun 2014, 10:38
by Titus
Does it work with the Apple USB charger ? they have a higher power like 1A
Titus
Posted: 19 Jun 2014, 22:42
by sailor
The higher the better, provided it is a 5 Volt USB standard charger.
Posted: 20 Jun 2014, 09:15
by Titus
Apple USB Charger (at least for iPhone 5) is 5V / 1A. So good for OSTC ?
Can some one from HW confirm ?
Titus
Posted: 21 Jun 2014, 09:29
Works fine for OSTC 2N or OSTC 2C.
Posted: 23 Jun 2014, 09:13
by Titus
Thanks Matthias ! (tu)
