When I do a dive on a high GF of 80 for example, after I have surfaced I get a slowly reducing GF shown on the surface mode screen. That I can understand, but why does it start off higher than 80%
Surely if I haven't broken 80% on the ascent, it can't be higher than that after 10 minutes on the boat.
The only thing I can think of is that the figure shown on the surface mode screen is the percentage of the set GF. So if it shows 85, that is 85% of 80, ie 65%.
What is the GF displayed in surface mode?
Re: What is the GF displayed in surface mode?
maybe the GF80 refers to the last deco stop?
So if you are at 80% on 3 meters it will be a little more on the surface?
How high did the GF display go after surfacing?
Reiner
Reiner
Which percent do you talk of? The one in the tissue diagram or the "GF:" surface information?
edhowarth
heinrichsweikamp Wrote:
> Hi,
> regards,
> Matthias
The GF surface information.
> Hi,
> regards,
> Matthias
In surface mode the OSTC computes your tissues in the non-gf model so this GF info is the relative factor (As you guessed above) to GF_High. Any value>100 means you have missed a decostop.
edhowarth
Fantastic. Thanks for your help, Matthias.
Ed
Ed
