OSTC Sport: New Firmware 10.17
The new OSTC Sport firmware 10.17 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
CHANGE: Range of Custom GF_lo now from 20 to 95
CHANGE: Automatically abort connection fail after 2mins
BUGFIX: Fast Gas change near the ppO2 limit could cause switching to a non-available Gas #0
BUGFIX: There was a 1:4096 chance that a portion of a dive was not stored correctly resulting in download issues
This Update also fixes the download to PC issue from the 10.16:
BUGFIX: Fix PC download issue for dives made with 10.16 firmware
divejy
Re: OSTC Sport: New Firmware 10.17
Post by divejy »
Bingo, thanks and I downloaded my divelogs.
vieux singe
Post by vieux singe »
Same with me!
Jan0711
Post by Jan0711 »
In divelogs 5 and Sub Surface Dives are now loaded.
The transfer to DiveMate (Android) is not possible!
In DiveMate:
> Information loaded - i.o.
> Old dives loaded - i.o.
> New dives remain at 99% - n.i.o.
I have the Samsung S3 Mini and Galaxy Tab. 3. The same problem.
Do you have any way to check that?
oh3mbc
Post by oh3mbc »
Going to dive today quite directly after work, and running 10.16.
Should i go home and update first?
You can safely dive with the 10.16.
Just update before downloading to the PC.
nicolas.villatte
Post by nicolas.villatte »
Hi, I experience the same issue as Jan0711 when trying to transfer via Bluetooth to DiveMate on Samsung Galaxy S5.
The data transfer fails after timeout.
Data was created with firmware 10.16, transfer was attempted first with Firmware 10.16 and then with 10.17 with same error.
Is there a way to fix the transfer of dives made in 10.16?
Are the dives still shown with 10.16 in the internal logbook? Even when 10.17 is installed?
Jan0711
Post by Jan0711 »
The problem with Divemate is now fixed in my case!
I have transferred the old dives over SubSurface. Then only the new transfer with new software 10.17 ...
regards
Jan
... and sorry my english is not good as well ! :-)
Continue here: read.php?6,15070
