Hello Matthias,
Coming back from my first dive with 1.36 - everything ok during my dive - I had a look at my logbook. As I checked my last dive but one, the ostc switched off with no way to take it back to life... until I reseted it from the usb interface.
The bug is repeatable: I just have to have a look at that dive. I noticed that the curve is corrupted: as it's drawing correctly when I select that dive, the end of the curve looks very special (like going down to 70m in 1mn and back and down and... crash !).
Everything is ok now - this message is just for information. Let me know if I can make anything to help debugging.
Olivier
Corrupted log
Re: Corrupted log
Hello Olivier,
This is due to a bad dive in the memory (Caused by one beta version who had a bug in writing the correct logbook data). You can re-format the memory by selecting a different dive and choose "Del. all" from the Logbook-Menu.
Re: Corrupted log
Hello Matthias,
When deleting all dives in my logbook, there's still one which is surviving... and killing my ostc when I try to have a look at it ! I'm simulating one more dive, checking it, delete all but... still the corrupted one. Any tip ?
Thanks and regards
Olivier
Thanks and regards
Olivier
Re: Corrupted log
Hello Olivier,
Please try again with the attached version, I could fix a potential problem a few minutes ago.
Re: Corrupted log
Worked fine with 1.37, thanks and congratulations !
