hwOS for OSTC3, cR and OSTC 2: 1.82 beta
Long time no beta version for the hwOS. Attached to this post is the new 1.82 beta with some new features for testers:
CHANGE: change button sensitivity range and default (OSTC2)
NEW: MOD Warning (Can be disabled)
NEW: Depth dependend ascend speed (Can be disabled)
NEW: Graphical speed indicator (Can be disabled)
NEW: Option to always show the ppO2, shows ppO2 for Diluent in CC mode
NEW: Mode Auto SP: Automatically switches the SP during descent (CC Mode)
NEW: Deco planer computes gas consumption for all gases and can compute bailout plans for CC modes
Please use only in the simulator or when carrying a backup computer during diving.
Downgrading to the 1.81 is, as always, possible and will not corrupt any settings or logbook data.
Enjoy the weekend,
Henrik S
Re: hwOS for OSTC3, cR and OSTC 2: 1.82 beta
Post by Henrik S »
(tu)
ClaudeDive
Post by ClaudeDive »
Matthias,
[left][/left]
Thanks for 1.82 beta and for giving us details about the new setting "variable speed" Depth dependend ascend speed (Can be disabled)
[left][/left]
[left][/left]
Cheers ;)
ClaudeDive
Matthias,
[left][/left]
Translation, English / French new parameters 1.82 beta
[left][/left]
Menu Déco > "Always show ppO2" = "Afficher pO2"
[left][/left]
Réglages > Préfér. Réglages > Suite ... >
[left][/left]
"MOD Warning" = "Alerte MOD"
[left][/left]
"Variable speed" = "Vitesse Variable"
[left][/left]
"Speed graph" = "Graph. Vitesse"
[left][/left]
Simulateur > Réglages >
[left][/left]
"Bottom Gas" = "Gaz Fond"
[left][/left]
"Deco Gas" = "Gaz Déco"
[left][/left]
Simulateur > Start Simulateur >
[left][/left]
"Ceiling" = "Prof.Plafond" or "Plafond"
[left][/left]
[left][/left]
Cheers ;)
steficic
Post by steficic »
Dear Matthias,
I have buttons sensibility problems with my new OSTC 2, FW 1.81.
Buttons are sometimes very, very hard to press. Sometimes both, sometimes just one. The sensibility gets normal after a reboot. It's hard to get the reboot, because when it happens you can't move in menu with fingers. I had to use a peace of wood to push buttons. I found that it happens with 40% (default) and also with 20% buttons sensibility too.
Will FW 1.82 solve this problems? Where can I get the 1.82 beta?
Boris
jak
Post by jak »
Hi steficic,
attachment linked to the first post.
http://forum.heinrichsweikamp.com/file.php?6,file=723,filename=v_182beta_ostc3_firmware.zip
R, Janos
I had the same issue with another brand computer using the same buttons.
One button just didn't want to react on pressing, no matter how hard I pressed it.
The problem was solved by sligthly tapping the button with my finger.
Reiner
The term "Sensitivity" is a bit problematic because lower values mean higher sensitivity... As soon as I have found a better name this will be renamed.
The buttons are new and in some kind different to our old ones:
- The membrane is three times as thick as in the old ones. That results in much more robustness and lower sensitivity. Unfortunately we had some users using a boltsnap to tap on them. This resulted in replacing quite a lot of buttons recently... The new buttons are more robust.
- The buttons are optimized for temperatures between zero and 25 degrees. Especially when it's very hot they are stiffer then intend, unfortunately. This is going to be changed with a firmware update at some point.
ocramx
Post by ocramx »
last week I've buyed ostc2...I meet problems with sensitivity of left button,it's very hard to push with 40%...once set to 20% it's gonna better,but not ever.sometimes it not react well,so you have to push it strongly.
Firmware vertion 1.81
No problems meet with right button,this work properly.
steficic
Post by steficic »
what about "NEW: Mode Auto SP: Automatically switches the SP during descent (CC Mode)"
I can't find it in the menu.
Boris
Hello Boris,
Menu -> CCR Setup -> CCR Mode: Auto And the OSTC will select the SP2-5 (It starts with SP1) during the descent.
steficic
Post by steficic »
Hello Matthias,
under
Menu -> CCR Setup
I have only
Diluent Setup
Fixed Setpoints
Exit
No "CCR Mode" :-(
FW is v1.82
Boris
That's unfortunately, true. The OSTC2 does not yet support "Auto SP" mode. Will be available in the next version.
steficic
Post by steficic »
OK, Thanks Matthias
Waiting ... :-)
