Hi all,
I just received my OSTC 3 today and try to connect it to my PC using the BT interface ...
Stupid question: where can I activate the BT in the OSTC 3? The manual says it's in the main menu, but it is not! I tried to search in Settings ... and found nothing!
Thank you for your help!
OSTC 3 cannot find bluetooth option
Re: OSTC 3 cannot start bluetooth
If it's not in settings (2nd entry) then reboot the unit from the reset menu (Will not change any settings).
Thank you for your quick reply. I have already rebooted the device, it didn't change anything. My main menu looks like this:
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
... and that's all ... any idea?
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
Anyway there is no space on the screen for an extra menu item ...
Go into "Settings". It's either in "Settings" or in one of the submenus from "Settings" (Depending on your current firmware).
MAIN MENU
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
Settings menu:
Information
Set Time & Date
Display Settings
Language
Reset Menu
More...
Exit
More... menu:
Compass calibration
Logbook offset
Units
Sampling rate
Salinity
Exit
and that's all!
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
Settings menu:
Information
Set Time & Date
Display Settings
Language
Reset Menu
More...
Exit
More... menu:
Compass calibration
Logbook offset
Units
Sampling rate
Salinity
Exit
and that's all!
Serial is 3106
Firmware is 1.74
Just upgraded the FW to 1.87 using USB ... same issue, still no bluetooth option
Firmware is 1.74
Re: OSTC 3 cannot find bluetooth option
Found the problem: dealer is France is selling "old" USB models without bluetooth. Will exchange the unit. You can close the topic.
Thank's for the support.
