OSTC 3 cannot find bluetooth option
Posted: 24 Aug 2015, 13:22
by Pat
I just received my OSTC 3 today and try to connect it to my PC using the BT interface ...
Stupid question: where can I activate the BT in the OSTC 3? The manual says it's in the main menu, but it is not! I tried to search in Settings ... and found nothing!
Thank you for your help!
Re: OSTC 3 cannot start bluetooth
Posted: 24 Aug 2015, 13:30
If it's not in settings (2nd entry) then reboot the unit from the reset menu (Will not change any settings).
Posted: 24 Aug 2015, 13:35
by Pat
Thank you for your quick reply. I have already rebooted the device, it didn't change anything. My main menu looks like this:
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
... and that's all ... any idea?
Posted: 24 Aug 2015, 13:37
by Pat
Anyway there is no space on the screen for an extra menu item ...
Posted: 24 Aug 2015, 13:50
Go into "Settings". It's either in "Settings" or in one of the submenus from "Settings" (Depending on your current firmware).
Posted: 24 Aug 2015, 13:56
by Pat
MAIN MENU
Logbook
OC Gas Setup
CCR Setup
Simulator
Deco Mode
Settings
Exit
Settings menu:
Information
Set Time & Date
Display Settings
Language
Reset Menu
More...
Exit
More... menu:
Compass calibration
Logbook offset
Units
Sampling rate
Salinity
Exit
and that's all!
Posted: 24 Aug 2015, 14:28
by Pat
Serial is 3106
Firmware is 1.74
Just upgraded the FW to 1.87 using USB ... same issue, still no bluetooth option :-(
Re: OSTC 3 cannot find bluetooth option
Posted: 24 Aug 2015, 21:22
by Pat
Found the problem: dealer is France is selling "old" USB models without bluetooth. Will exchange the unit. You can close the topic.
Thank's for the support.
