Sport, BT & Wind10
Motardplongeur
Sport, BT & Wind10
Hello
I'm not able to connect my Sport to my computer (Win 10) with BT (I have a Asus BT400 dongle).
No problem between Sport & a Samsung "tablet" (by DiveMate) ; link has been established within a few seconds.
Ok between the Samsung tablet & my comptuer (but not so easy to win !).
And nothing with my Sport.
I see 2 different ports (8 & 11, I don't know why two ! ; both are mentionned "input" "entrant" in french), everything seems to be ok, but just seems !
Subsurface : "error, unable to connect Sport"
Companion : same kind of message
For both ports.
To be noticed : Companion is very slow as I want go inside parameter menu and bug several times.
Anybody has an idea ?
For both ports.
OSTC #12002 & #11150
Re: Sport, BT & Wind10
It seems that there is some incompatibility with the new Windows 10 Bluetooth stack and the current OSTC PC Programs: http://answers.microsoft.com/en-us/wind ... b46?page=1
While the described work-around worked here on a WIN10 PC, it failed on another. So there definitely is some issue here we need to fix.
We're already discussing this with PC program developers and ask for your patience here.
Motardplongeur
OK, I'll wait ; that's not a big problem !
hallo,
gibts schon news/workaround zu diesem problem - wäre cool wenn man eine offizielle warning posten würde, dass man mit dem windows update auf W10 warten sollte - ansonsten werden noch einige ihre OSTCs nicht mehr abgleichen können nach dem update
gruss
Fredy
gruss
Fredy
Sieht so aus als würde das Problem mit einem Windows-Update demnächst behoben (Hoffentlich): http://answers.microsoft.com/en-us/wind ... b46?page=3
Looks like the issue is beeing fixed with a Windows-Update soon (Hopefully): http://answers.microsoft.com/en-us/wind ... b46?page=3
cross fingers!
danke für die info - melde mich wenn es bei mir läuft
gruss
Fredy
gruss
Fredy
cyberdiamond
I can confirm that this is fixed in a preview build (10532) of Windows 10.
Just tested with subsurface (daily beta build) and updating firmware, changing dive computer settings and downloading dives all worked.
Edit:
I tested using a Bluetooth OSTC3+ (non sport) but mine also didn't work using the release build of Windows 10.
Edit:
OSTC3 #756 / #4491
Thanks for the information - Our research clearly indicates a faulty Win10 bluetooth implementation and that Microsoft is going to release a fix for this soon.
habe gestern (1.10.2015) das aktuelle Windows Update aufgespielt und seit dem läuft der abgleich OSTC3+/Win10/Divinglog 6.0 bei mir mit dem Hama Blootooth USB Adapter 4.0 problemlos (keine zusätzlichen Dirvers von Hama installiert).
gruss
Fredy
gruss
Fredy
Der Microsoft Patch "KB3093266" behebt dieses Problem. Einfach über Windows-Update installieren.
The Microsoft patch "KB3093266" fixes this issue. Can be installed via Windows-updates.
Motardplongeur
Fine !
That works on Companion ; I made the 10.20 update.
But not with Subsurface (4.5 beta 2).
Motardplongeur
Hum hum, how to say ...
Now, the link by BT with Subsurface is ok but when I try to take parameters from Sport, that stops at 92%.
Done 2 ou 3 time without anything else.
