Page 1 of 2
V1.40 Stable
Posted: 30 Jun 2009, 12:00
The new stable 1.40 is now available for download!
Die Stabile version 1.40 ist nun verfügbar!
Viele Grüsse/Regards,
Re: V1.40 Stable
Posted: 30 Jun 2009, 12:27
by diego
Ciao
Sorry for my english,but where is the new stable 1.40 for download?
saluti
Diego
Re: V1.40 Stable
Posted: 30 Jun 2009, 12:32
Get the file here: V1.40 Stable
Re: V1.40 Stable
Posted: 30 Jun 2009, 19:18
by Jostein
Vielen Dank für die neue Version! Wird gleich mal ausprobiert.
Jostein
Re: V1.40 Stable
Posted: 30 Jun 2009, 19:48
by Anonymous User
diego Wrote:
> Ciao
> 1.40 for download?
> saluti
> Diego
I download the .zip file in the link and extract it and I get a file without hex extensions.
Same for bootloader in the download section.
Neither file works when adding the missing .hex extension or missing .exe extension.
Something wrong either at my end or your end!
Re: V1.40 Stable
Posted: 30 Jun 2009, 20:18
by sailor
Hallo, bei mir gehts auch nicht, Gruss, Reiner
Re: V1.40 Stable
Posted: 30 Jun 2009, 20:55
by pem
Hello,does this version have the ave depth and stopwatch i enquired about on a previous occasion? thanks,simon.
Re: V1.40 Stable
Posted: 30 Jun 2009, 20:59
by pem
i HAVE ALSO NOT BEEN ABLE TO EXTRACT ANYTHING FROM THE ZIP FILE
Re: V1.40 Stable
Posted: 30 Jun 2009, 22:05
by Anonymous User
Works now.
Flashing and will test dive tomorrow.
Have the problems with deco on CCR been fixed on this version?
Re: V1.40 Stable
Posted: 01 Jul 2009, 10:09
by andersnasman
Sorry, I cannot open the ZIP archive either...
Re: V1.40 Stable
Posted: 01 Jul 2009, 10:11
Works fine here - it was packed just as all the other releases. As usual, it contains the HEX and two text files.
Re: V1.40 Stable
Posted: 01 Jul 2009, 10:13
> thanks,simon.
Average depth is included and tested in all modes. Stopwatch is also in the code but is not displayed yet. I was unsure where to put it on the screen.
Re: V1.40 Stable
Posted: 01 Jul 2009, 10:14
> this version?
There are no known deco issues in this version. We have tested this version intensively.
Re: V1.40 Stable
Posted: 01 Jul 2009, 11:35
by corona_citron
CCR dive - 57m 70 minutes.... no problems
Re: V1.40 Stable
Posted: 01 Jul 2009, 12:14
by andersnasman
I succeeded in opening the archive with 7-zip however Windows filemanager complains about the zip file beeing broken or not valid.
I'll try th S/W this weekend.
Re: V1.40 Stable
Posted: 01 Jul 2009, 12:21
by Ferdy
Ich hatte unter Linux keinerlei Probleme mit dem .zip File. Und auch die .hex ließ sich problemlos installieren.
Andreas
Re: V1.40 Stable
Posted: 01 Jul 2009, 12:28
by pem
heinrichsweikamp Wrote:
> Hello,
> two text files.
> regards,
Hello Matthias,could the stopwatch go under the current dive time in gauge mode and be started and reset with the select button? this would be really useful,thanks,simon.
Re: V1.40 Stable
Posted: 01 Jul 2009, 16:04
by divinglog
No problems with the zip file using Winzip.
Re: V1.40 Stable
Posted: 01 Jul 2009, 19:19
by nicolas schreyer
hello,
what is the difference between the 1.38 beta and the 1.40 stable ?
Re: V1.40 Stable
Posted: 01 Jul 2009, 20:25
by Anonymous User
First dive on 1.40 and it was nice.
The main problem encountered is the legibility of the smaller numbers (i.e. Setpoint, temperature, average depth).
They are all very legioble on the surface, but diving it is just number guessing. At leat the Setpoint has to be bigger (to make sure theright setpoint is selected).
Bear in mind I dive in caves (water is crisp clear), but with powerful lights in pitch darkness (and the water is clear long range, but short range there is some distortion when reading small numbers nearby) and this is where I find the problem.
Probably down to 100 meters (or past 70 meters) even in clear water one would have a similar problem.
Re: V1.40 Stable
Posted: 01 Jul 2009, 20:29
by sailor
still unable to download or unpack this file on two different computers with Vista and XP
no problem at all with 1.38 ! ! !
Re: V1.40 Stable
Posted: 01 Jul 2009, 20:39
Hello Reiner,
This is direct link: code140.zip and (just in case) I have it attached to this post, too. I've tested this file with a number of zip tools on different computers and systems, so if it does not work at your place - try again in 24hours.
Re: V1.40 Stable
Posted: 01 Jul 2009, 20:50
by angelain
Matthias , don't know what is wrong, but I get this message from winzip(see attachment)
Re: V1.40 Stable
Posted: 01 Jul 2009, 23:38
by sailor
This is my fault-message.
I'll try again tomorrow.
Re: V1.40 Stable
Posted: 02 Jul 2009, 09:57
by Steve
no problems extracting the file
