Battery display / Batterieanzeiger
Posted: 24 Oct 2015, 15:51
by jgl51
I just updated my OSTC to version 3.1.
After the update the battery indicator shows a discharged battery and blinks although voltage was aroud 3.8V.
I charged it overnight, voltage is now 4.2 V but indicator still blinks and shows an almost totally discharged battery.
How can I solve this problem???
Thanks in advance
PS: Francais, English oder Deutsch OK
Re: Battery display / Batterieanzeiger
Posted: 26 Oct 2015, 10:30
Check/Reset CF74 to 1800. After a full recharge and disconnecting the USB the blinking will stop and the battery indicator will be full.
Posted: 26 Oct 2015, 22:18
by jgl51
Changed current CF 74 from 0 to 1800 and now it is fine.
Thank you!
Posted: 01 Nov 2015, 18:55
by Olaf_D
danke für die Änderung der Batterieanzeige in 3.10. So macht das Sinn.
Im Sommer stand die Anzeige bei mir nach einem Urlaub immer noch auf voll bei On-time von ca. 15 Std. Das war dann nicht mehr ganz plausibel.
So ist es deutlich besser !
Grüße
Olaf
