Page 1 of 2
New 3.13 Firmware
Posted: 11 Jan 2016, 12:40
Today, we released the 3.13 stable for the OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00
(Changes since 3.11):
NEW: Logbook shows markers with small orange boxes in the profile
BUGFIX: Minor layout fix (Battery warning in divemode)
CHANGE: Color-code battery % display in surface mode (Charge, Full, Normal)
BUGFIX: "First Diluent" and "SP Mode" used same EEPROM location
NEW: Quit Simulator automatically when starting a real dive
CHANGE: Battery percent based on ON-Time instead of battery voltage
BUGFIX: Fix licence in German
BUGFIX: Fix minor layout bugs in surface mode
NEW: Auto Setpoint switch function (CC Modes)
BUGFIX: 1st line in logbook was not displayed in rare cases (2C hardware)
BUGFIX: Divetime had unwanted "." behind the minutes
BUGFIX: Entry time in logbook when dive was around midnight
BUGFIX: Show manually set O2 (Gas 6) correctly
BUGFIX: Show dives with >999mins divetime correctly
BUGFIX: Fix color codes 192-223 (Mk.2 and 2N only)
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2:
http://heinrichsweikamp.com/service/software
2. Follow the step-by-step instructions:
http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.13 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen:
2. Die einfache Schritt-für-Schritt Anleitung befolgen:
http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Re: New 3.13 Firmware
Posted: 11 Jan 2016, 13:24
by scubatinoo
Vielen Dank euch! (tu)
Posted: 12 Jan 2016, 04:20
by Clownfish
Upgraded. Make sure you fully charge computer after upgrade as it resets the battery to 100%.
Posted: 17 Jan 2016, 16:22
by Dahab Boris
Thanks for your continued support
-D
Posted: 07 Feb 2016, 18:37
by PAOLO
(tu):)-D
Paolo
Posted: 08 Feb 2016, 19:49
by WG
I gave it a couple of tries, but always get following error message when I try to start the process:
HeinrichsWeikamp Bootloader v2
Support:
info@heinrichsweikamp.com
Looking for
http://www.heinrichsweikamp.net/autofirmware/ostc2.hex
Could not access site information
Looking for
Looking for
Connected to \\.\COM4 at 115200
Searching for PIC ...
Found:18F 4685
Looking for
what should I do differently?
Walter
OSTC 2531
Posted: 09 Feb 2016, 20:28
by WG
fixed, tried it on another computer. All OK now. Thanks for your support
Walter
Posted: 23 Feb 2016, 11:59
Hi Walter,
Even if you have solved this, the error indicates that the bootloader can not connect to our website. Maybe it was blocked from a firewall on the PC? Or, you did not had an active internet connection at this time.
Posted: 24 Feb 2016, 11:07
by Crickers
Have just upgraded my 2N to 3.13, have there been any updates to the custom functions?
The latest CF list I can find is v2.94
Nick
Posted: 12 Mar 2016, 22:41
by buk@nero
I have the same doubt. Are there new Custom functions, or do the ones for 2.94 apply?
Thanks for the update.
Crickers Wrote:
> Hi,
> Thanks
> Nick
Posted: 13 Mar 2016, 10:19
by Clownfish
No changes as far as I can see.
Posted: 13 Mar 2016, 15:51
by Laurie_the_Knot
The only change to Custom Function that I can see is in the implementation of CF31. Before V3.12 it showed battery voltage. At V3.12 and after it shows battery percentage (%). This represents the percentage of "on" time based on the setting of CF74.
Posted: 25 Apr 2016, 17:46
by Lee Chenyu
hi!guys,after update, the battery bar shows low(green ,not red )and blinking.
need to wait until the battery bar shows 100% ?
Posted: 25 Apr 2016, 17:49
It's the second thread from the top (Marked: "FAQ: Battery blinking"...)
read.php?2,16518
Posted: 26 Apr 2016, 02:21
by Lee Chenyu
(:P) thanks
Posted: 15 May 2016, 14:03
by awanadive
> CF74.
Hello, I was unable to find my answer: is it still possible with fw 3.13 to show the battery voltage?
Thank you!
AwanaDive
Posted: 11 Aug 2016, 18:55
by Theis Thorup
Hey Guys
Since updating to 3.13 my watch is running very fast? gaining 20 mins in a month or so?
Best,
Theis
Posted: 11 Aug 2016, 21:45
by edhowarth
Have a look at custom function CF48: Time offset/day
This Custom Function will correct the internal clock. The Value represents a number of seconds that will
be added to the clock at midnight.
Default value: 0:00s
Suggested range: -2:00s...+2:00s
Posted: 11 Aug 2016, 22:21
by Theis Thorup
Thank you but I imagine that would give an immediate offset and not add something like 30 secs a day?
Posted: 12 Aug 2016, 10:28
by edhowarth
No. It adds each day. At midnight.
I don't know what the maximum seconds it will do each day, but it'll be easy enough to test
Posted: 12 Aug 2016, 12:16
by Laurie_the_Knot
At midnight each day the software will decrement the clock by up to 120 seconds or increment it by 120 seconds.
Unfortunately there is a bug in the code which causes any attempt to increment by more than 59 seconds to decrement the clock.
So the practical range is -120 seconds (2:00 mins) to +59 seconds.
Posted: 19 May 2017, 17:27
by Frank D
Hi!
Where can I download this version's custom functions list ?
Frank (OSTC2N #4020)
Posted: 05 Oct 2018, 10:48
by jozzbee
Has there been any response on Frank's request?
I'm struggling too, finding the list of v3.13 C/F
Posted: 05 Oct 2018, 13:26
The link is in the 2nd thread in this forum called " OSTC2 Custom Functions documentation":
https://forum.heinrichsweikamp.com/read.php?2,8503
https://www.angermayr.eu/index.php/de/s ... s-download
Since the 2.94 BETA, no new CFs were added. So the docsument is still valid.
Posted: 19 Oct 2018, 01:58
by Isdahl
Hi
Im using an older OSTC 2N with firmware V2.02
Im just wondering if it straight forward to do a update to firmware V3.13
And if there is a step by step guide..
Seems that it can be tricky ?? And problem with USB drivers ??
Petter
