New 3.13 Firmware
New 3.13 Firmware
Today, we released the 3.13 stable for the OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.11):
NEW: Logbook shows markers with small orange boxes in the profile
BUGFIX: Minor layout fix (Battery warning in divemode)
CHANGE: Color-code battery % display in surface mode (Charge, Full, Normal)
BUGFIX: "First Diluent" and "SP Mode" used same EEPROM location
CHANGE: Battery percent based on ON-Time instead of battery voltage
BUGFIX: Fix licence in German
BUGFIX: Fix minor layout bugs in surface mode
NEW: Auto Setpoint switch function (CC Modes)
BUGFIX: 1st line in logbook was not displayed in rare cases (2C hardware)
BUGFIX: Divetime had unwanted "." behind the minutes
BUGFIX: Entry time in logbook when dive was around midnight
BUGFIX: Show manually set O2 (Gas 6) correctly
BUGFIX: Show dives with >999mins divetime correctly
BUGFIX: Fix color codes 192-223 (Mk.2 and 2N only)
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2: http://heinrichsweikamp.com/service/software
2. Follow the step-by-step instructions: http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.13 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen: http://heinrichsweikamp.com/service/software
2. Die einfache Schritt-für-Schritt Anleitung befolgen: http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Clownfish
Re: New 3.13 Firmware
Upgraded. Make sure you fully charge computer after upgrade as it resets the battery to 100%.
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Dahab Boris
PAOLO
Thanks for your continued support
(tu):)-D
Paolo
(tu):)-D
Paolo
WG
I gave it a couple of tries, but always get following error message when I try to start the process:
HeinrichsWeikamp Bootloader v2
Looking for http://www.heinrichsweikamp.net/autofirmware/ostc2.hex
Could not access site information
Connected to \\.\COM4 at 115200
Searching for PIC ...
Found:18F 4685
what should I do differently?
Walter
OSTC 2531
Found:18F 4685
Walter
OSTC 2531
WG
fixed, tried it on another computer. All OK now. Thanks for your support
Walter
Walter
Hi Walter,
Even if you have solved this, the error indicates that the bootloader can not connect to our website. Maybe it was blocked from a firewall on the PC? Or, you did not had an active internet connection at this time.
Crickers
Have just upgraded my 2N to 3.13, have there been any updates to the custom functions?
The latest CF list I can find is v2.94
Nick
Nick
OSTC 2n #4315
buk@nero
I have the same doubt. Are there new Custom functions, or do the ones for 2.94 apply?
Thanks for the update.
Crickers Wrote:
> Hi,
> Thanks
> Nick
Crickers Wrote:
> Hi,
> Thanks
> Nick
Clownfish
Laurie_the_Knot
The only change to Custom Function that I can see is in the implementation of CF31. Before V3.12 it showed battery voltage. At V3.12 and after it shows battery percentage (%). This represents the percentage of "on" time based on the setting of CF74.
Happy diving,
Laurie (OSTC2 #11454)
Lee Chenyu
hi!guys,after update, the battery bar shows low(green ,not red )and blinking.
need to wait until the battery bar shows 100% ?
awanadive
> CF74.
Hello, I was unable to find my answer: is it still possible with fw 3.13 to show the battery voltage?
Thank you!
AwanaDive
> CF74.
Thank you!
AwanaDive
OSTC2N -- #5956 -- FW 3.13 EN
Theis Thorup
Hey Guys
Since updating to 3.13 my watch is running very fast? gaining 20 mins in a month or so?
Best,
Theis
Best,
Theis
edhowarth
Have a look at custom function CF48: Time offset/day
This Custom Function will correct the internal clock. The Value represents a number of seconds that will
be added to the clock at midnight.
Default value: 0:00s
Suggested range: -2:00s...+2:00s
Theis Thorup
Thank you but I imagine that would give an immediate offset and not add something like 30 secs a day?
edhowarth
No. It adds each day. At midnight.
I don't know what the maximum seconds it will do each day, but it'll be easy enough to test
Laurie_the_Knot
At midnight each day the software will decrement the clock by up to 120 seconds or increment it by 120 seconds.
Unfortunately there is a bug in the code which causes any attempt to increment by more than 59 seconds to decrement the clock.
So the practical range is -120 seconds (2:00 mins) to +59 seconds.
Happy diving,
Frank D
Hi!
Where can I download this version's custom functions list ?
Frank (OSTC2N #4020)
jozzbee
Has there been any response on Frank's request?
I'm struggling too, finding the list of v3.13 C/F
jozzbee (OSTC 2c #7496)
The link is in the 2nd thread in this forum called " OSTC2 Custom Functions documentation": https://forum.heinrichsweikamp.com/read.php?2,8503
https://www.angermayr.eu/index.php/de/s ... s-download
Since the 2.94 BETA, no new CFs were added. So the docsument is still valid.
Isdahl
Hi
Im using an older OSTC 2N with firmware V2.02
Im just wondering if it straight forward to do a update to firmware V3.13
And if there is a step by step guide..
Seems that it can be tricky ?? And problem with USB drivers ??
Petter
Petter
