New 3.13 Firmware
New 3.13 Firmware
Today, we released the 3.13 stable for the OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.11):
BUGFIX: Fix licence in German
1. Get new bootloader v2: http://heinrichsweikamp.com/service/software
2. Follow the step-by-step instructions: http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.13 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
1. Neuen bootloader v2 herunterladen: http://heinrichsweikamp.com/service/software
2. Die einfache Schritt-für-Schritt Anleitung befolgen: http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Re: New 3.13 Firmware
Upgraded. Make sure you fully charge computer after upgrade as it resets the battery to 100%.
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Dahab Boris
Thanks for your continued support
(tu):)-D
Paolo
(tu):)-D
Paolo
I gave it a couple of tries, but always get following error message when I try to start the process:
HeinrichsWeikamp Bootloader v2
Looking for http://www.heinrichsweikamp.net/autofirmware/ostc2.hex
Connected to \\.\COM4 at 115200
Searching for PIC ...
Found:18F 4685
what should I do differently?
Walter
OSTC 2531
Found:18F 4685
Walter
OSTC 2531
fixed, tried it on another computer. All OK now. Thanks for your support
Walter
Walter
Hi Walter,
Even if you have solved this, the error indicates that the bootloader can not connect to our website. Maybe it was blocked from a firewall on the PC? Or, you did not had an active internet connection at this time.
Have just upgraded my 2N to 3.13, have there been any updates to the custom functions?
The latest CF list I can find is v2.94
Nick
Nick
OSTC 2n #4315
I have the same doubt. Are there new Custom functions, or do the ones for 2.94 apply?
Thanks for the update.
Crickers Wrote:
> Hi,
> Thanks
> Nick
Crickers Wrote:
> Hi,
> Thanks
> Nick
Laurie_the_Knot
The only change to Custom Function that I can see is in the implementation of CF31. Before V3.12 it showed battery voltage. At V3.12 and after it shows battery percentage (%). This represents the percentage of "on" time based on the setting of CF74.
Happy diving,
Laurie (OSTC2 #11454)
Lee Chenyu
hi!guys,after update, the battery bar shows low(green ,not red )and blinking.
need to wait until the battery bar shows 100% ?
> CF74.
Hello, I was unable to find my answer: is it still possible with fw 3.13 to show the battery voltage?
Thank you!
AwanaDive
> CF74.
Thank you!
AwanaDive
OSTC2N -- #5956 -- FW 3.13 EN
Theis Thorup
Hey Guys
Since updating to 3.13 my watch is running very fast? gaining 20 mins in a month or so?
Best,
Theis
Best,
Theis
Have a look at custom function CF48: Time offset/day
This Custom Function will correct the internal clock. The Value represents a number of seconds that will
be added to the clock at midnight.
Default value: 0:00s
Suggested range: -2:00s...+2:00s
Theis Thorup
Thank you but I imagine that would give an immediate offset and not add something like 30 secs a day?
No. It adds each day. At midnight.
I don't know what the maximum seconds it will do each day, but it'll be easy enough to test
Laurie_the_Knot
At midnight each day the software will decrement the clock by up to 120 seconds or increment it by 120 seconds.
Unfortunately there is a bug in the code which causes any attempt to increment by more than 59 seconds to decrement the clock.
So the practical range is -120 seconds (2:00 mins) to +59 seconds.
Happy diving,
Hi!
Where can I download this version's custom functions list ?
Frank (OSTC2N #4020)
Has there been any response on Frank's request?
I'm struggling too, finding the list of v3.13 C/F
jozzbee (OSTC 2c #7496)
The link is in the 2nd thread in this forum called " OSTC2 Custom Functions documentation": https://forum.heinrichsweikamp.com/read.php?2,8503
https://www.angermayr.eu/index.php/de/s ... s-download
Since the 2.94 BETA, no new CFs were added. So the docsument is still valid.
Hi
Im using an older OSTC 2N with firmware V2.02
Im just wondering if it straight forward to do a update to firmware V3.13
And if there is a step by step guide..
Seems that it can be tricky ?? And problem with USB drivers ??
Petter
Petter
