OSTC Sport: New Firmware 10.26
The new OSTC Sport firmware 10.26 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
As it mainly contains internal changes updating from 10.25 is not mandatory this time.
Changes since 10.20 (Changes since 10.25):
NEW: Support for new logbook memory chip (minor hardware change)
CHANGE: Large font for current gas in gas setup
NEW: Allow GF settings configured through PC
BUGFIX: Fix missing gas setup (From 10.24)
NEW: Safety Stop can be enabled/disabled from the menu
BUGFIX: Fix rare issue after battery change (OSTC sport did not start properly)
CHANGE: Show velocity from 3m/min or more (Ascend or descent)
NEW: Segmented speed graph in divemode (optional)
NEW: Variable speed (7-20m/min) depending on depth (optional)
NEW: Safety Stop can be configured (Start-, End- and reset-depth + length of stop) via PC
NEW: Logbook marker can be set in dive mode menu
NEW: Logbook shows markers with small orange boxes in the profile
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
BUGFIX: Text alignment in logbook
NEW: Show actual dive count in logbook list view (If <1000)
BUGFIX: Minor language and text aligment fixes
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: +5min for stopwatch during simulation did not work
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
BUGFIX: BLE timings for MAC issues
BUGFIX: Battery consumption calculation in sleep mode (3,6V battery only)
Jetesson
Re: OSTC Sport: New Firmware 10.26
Post by Jetesson »
although updating from 10.25 is not mandatory, it has come to my attention that I cannot connect my OSTC Sport to my MAC...
error regarding:
Port is not defined.
Port : Port is not defined.
Error: Port : Port is not defined.
I've downloaded and installed Ostc Companion v3.00 beta 8
also downloaded and installed the FTDI drivers (although not necessary according forum posts)
OS X El Capitan v 10.11.6
Can you please advise what to do, as I always want to have the latest version.
Even though it's not necessary this time, but what with future releases if I cannot connect with my Mac?
Thanks in advance
Jurgen
Jetesson
Post by Jetesson »
Hi again,
i managed to connect it to my Mac but I cannot click the upgrade firmware button…
please advise.
Jurgen
Update without prior connecting.
Jetesson
Post by Jetesson »
Thank you for your quick reply Matthias.
I've already tried but get this instead:
Loading firmware.
Unable to open port /dev/tty.OSTCs0907-SPPDev
Error: Unable to open port /dev/tty.OSTCs0907-SPPDev
what else can I do?
thanks for your time en advice.
regards
Jurgen
have you seen the FAQ article about updating: read.php?6,14509 Scroll down, there is an alternative option to update with "subsurface", which works very well on the MAC.
Hope this helps...
Jetesson
Post by Jetesson »
Downloaded Subsurface but didn't really know what to do... again...
changed port to COM18 in OSTC Companion didn't work as expected.
changed it to previous port...
didn't know what happened but it worked
thanks for the help Matthias.
cheers
Off diving now
Jurgen
Continue here: read.php?6,17393
