OSTC Sport: New Firmware 10.26
Posted: 07 Jun 2016, 16:41
The new OSTC Sport firmware 10.26 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
As it mainly contains internal changes updating from 10.25 is not mandatory this time.
Changes since 10.20 (Changes since 10.25):
NEW: Support for new logbook memory chip (minor hardware change)
CHANGE: Large font for current gas in gas setup
NEW: Allow GF settings configured through PC
BUGFIX: Fix missing gas setup (From 10.24)
NEW: Safety Stop can be enabled/disabled from the menu
BUGFIX: Fix rare issue after battery change (OSTC sport did not start properly)
CHANGE: Show velocity from 3m/min or more (Ascend or descent)
NEW: Segmented speed graph in divemode (optional)
NEW: Variable speed (7-20m/min) depending on depth (optional)
NEW: Logbook marker can be set in dive mode menu
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
Re: OSTC Sport: New Firmware 10.26
Posted: 26 Sep 2016, 22:25
by Jetesson
although updating from 10.25 is not mandatory, it has come to my attention that I cannot connect my OSTC Sport to my MAC...
error regarding:
Port is not defined.
Port : Port is not defined.
Error: Port : Port is not defined.
I've downloaded and installed Ostc Companion v3.00 beta 8
also downloaded and installed the FTDI drivers (although not necessary according forum posts)
OS X El Capitan v 10.11.6
Can you please advise what to do, as I always want to have the latest version.
Even though it's not necessary this time, but what with future releases if I cannot connect with my Mac?
Thanks in advance
Jurgen
Posted: 26 Sep 2016, 23:39
by Jetesson
Hi again,
i managed to connect it to my Mac but I cannot click the upgrade firmware button…
please advise.
Jurgen
Posted: 27 Sep 2016, 10:39
Update without prior connecting.
Posted: 27 Sep 2016, 11:10
by Jetesson
Thank you for your quick reply Matthias.
I've already tried but get this instead:
Loading firmware.
Unable to open port /dev/tty.OSTCs0907-SPPDev
Error: Unable to open port /dev/tty.OSTCs0907-SPPDev
what else can I do?
thanks for your time en advice.
regards
Jurgen
Posted: 27 Sep 2016, 15:40
have you seen the FAQ article about updating: read.php?6,14509 Scroll down, there is an alternative option to update with "subsurface", which works very well on the MAC.
Hope this helps...
Posted: 27 Sep 2016, 17:32
by Jetesson
Downloaded Subsurface but didn't really know what to do... again...
changed port to COM18 in OSTC Companion didn't work as expected.
changed it to previous port...
didn't know what happened but it worked
thanks for the help Matthias.
cheers
Off diving now
Jurgen
Posted: 17 Nov 2016, 11:34
Continue here: read.php?6,17393
