Download Log from OSTC with DivingLog
BerndAllgäu
Post by BerndAllgäu »
Hi @ all!
At fisrt: sorry for my poor enlish ;)
Yesterday I did my First Dive with the OSTC and ppO2 Sensors. So during the dive worked all fine. I used the L-GF CC. Set Point -> Sensors.
Now I tried to download the Profile. It worked with DivingLog, but where are the Data from the Sensor Cells? I used the CF to enable the logging... (CF24 = 1)
Can somebody help me?
best regards Bernd
PS.: I posted in last Days the wish to Calibrate the Sensors with calculating the actual Air pressure. (but only in german)
I my diving area is the airpressure at 920 to 950 mbar. So the calibration is not correct when i use the gas setting in %. At the moment i help myself to use while calibration with air only 19%. It works, but I miss one decimal place to calibrate it accurate enough.
My idea would be: the specification of the calibration gas in the "O2 sensor menu. Indication of the gas with one decimal place.
Integration of the absolute air pressure in the calibration.
ppO2 [bar] = FO2 [%] * Airpressure [mbar] / 1000mbar
Maybe its possible to implement additional a 2-Point Calibration? Air and
e.g. 100% O2 (configurable)
for further questions and discussions contact me please.
Re: Download Log from OSTC with DivingLog
Hello Bernd,
As far as I know the O2 Data can not displayed from Divinglog (yet), sorry.
BerndAllgäu
is it possible to get the protokoll to download the data from the ostc by my own? so i can get the required datas in the way i need.
Regards, Bernd
Lastest version of the protocol description is attached.
BerndAllgäu
Danke! :)
divinglog
Post by divinglog »
Hallo Bernd
Wie Matthias schon richtig geschrieben hat, kann Diving Log leider im Moment die ppO2 Daten noch nicht im Logbuch ablegen (und damit anzeigen). Das ist aber auf jeden Fall für die zuküntige Version 5.0 geplant, ich arbeite gerade an den entsprechenden Datenbank Erweiterungen. Ein klein wenig wird es aber leider noch dauern.
Schöne Grüße,
Sven
BerndAllgäu
kein Problem - werde mir Zwischenzeitlich mit ner eigenen anwendung behlefen. Hab mir das Protokol schon angeschaut und die ersten Importversuche gemacht... sowas ist schließlich mein täglich Brot... ;)
MfG aus dem staubfreien Allgäu
Bernd
Divinglog mit Gaswechseln und ppO2 Graph wäre wirklich nett ;)
Grüsse,
divinglog
Post by divinglog »
Hallo Matthias
Ja, das steht schon (zu lange) auf der der ToDo Liste. Da steht leider die komplette Neuprogrammierung in .NET davor die momentan läuft. Das ist der Grund warum das so lange dauert, geschätzte 40.000 Zeilen Code dauern etwas ;)
Schöne Grüße,
Sven
