OSTC 2C Briked :(
Nimitz_BE
OSTC 2C Briked :(
Post by Nimitz_BE »
Hi All,
Last night I wanted to update my OSTC 2C 8539 from V3.11 to v3.13.
I used OSTC Planner on my MAC with OS X 10.10.5 for it.
I got the red screen on my 2C with written Bootloader etc. and after it nothing any more...
After 1 hours or so (I went eating) the screen was still black and no LED's on.
I disconnected it and try to wakeup pushing a button, but no luck screen stay black and when I reconnect the 2C on the computer also nothing :(
Today I tried to connect with TinyBootload 1, he says no PIC found. I tried also to do the reset with the magnet, USB plugged in. But still no PIC found.
What can I try to unbrick my OSTC, I go to a diving trip and I would like to use my OSTC and not my Zoop!
Re: OSTC 2C Briked :(
Very likely you can recover it with the bootloader v1 (Not v2). But it's only available for Windows. The trick is described here: read.php?2,4071 (See section "If you have firmware <1.90" )
Please also see "Note 2" in this article.
Nimitz_BE
Post by Nimitz_BE »
I tried with bootloader v1 on a win7 PC.
I get all the time Error :
[quote]Connected to \\.\COM5 at 19200
HEX: 279 days old, INHX32,18Fcode+cfg, total=92928 bytes.
ERROR![/quote]
I tried also with the magnet as discribed in "Note 2" but still no luck.
I will write a Email at info@heinrichsweikamp.com
Make sure the sequence is correct for this kind of update:
- Reset the OSTC with a quite strong magnet
- then click "Write Flash" within 10 seconds
Nimitz_BE
Re: OSTC 2C Briked [Solved] :)
Post by Nimitz_BE »
Thank's for this tips.
I did it.
But right it's on his way to HW, let's hope you have more chances as me.
Nimitz_BE
Post by Nimitz_BE »
Hi Matthias and HW team,
I got my OSTC 2c back and working.
Your service rocked!
Nicolas!
