Colours are inverted on the screen
Kris74
Post by Kris74 »
someone could help me, the colors on the screen changed. I only changed the parameter via the OSTC.
The menu is on white background as you can the on the photo. Nothing change with the RAz menu.
Thanks for your advice
Re: Colours are inverted on the screen
This is a mixture of a feature and a bug in your version.
Feature: The serial number should be displayed inverted when the firmware is older then one year.
Bug: The 1.86 has a bug that it inverts the main menu, as well.
Please upgrade to the latest 2.09 and it's fine again.
Kris74
Post by Kris74 »
-- moved topic --
Kris74
Post by Kris74 »
Thanks for your answer. I'll do it, but to tell the true, I've never connect the OSTC to my computer.
Is it a problem if I don't upgrade my OSTC? Does others problem will appear?
Three reasons why you should update.
a) It's free!
b) The changes and bugfixes since the 1.86:
BUGFIX: Compatibility with "hwOS Config" fixed
NEW: New hardware descriptor command 0x60 added (For PC programs)
CHANGE: Logbook marker temporally disabled in internal logbook
BUGFIX: Characters with descenders were not drawn correctly in rare cases
NEW: Support for different compass chip (Internal hardware change)
CHANGE: Language fixes
Release version for new OSTC2 (Minor internal hardware changes)
CHANGE: Remove ppO2 [Dil] from OC dive mode screen
NEW: Support for new logbook memory chip (minor hardware change)
BUGFIX: Button sensitivity was not reset after update in some cases
NEW: New Customview shows ppO2(O2) and ppO2(Diluent) during CCR mode
BUGFIX: Fix missing ccr setup menu (From 2.02)
BUGFIX: Fix rare issue after battery change (OSTC3 did not start properly)
BUGFIX: Divetime >99mins was not displayed (Only OSTC2 with serial > 10500)
BUGFIX: Minor layout fixes in divemode (Dynamic gaslist and stopwatch)
BUGFIX: Minor language updates
NEW: Logbook marker can be set in dive mode menu (OC only)
NEW: Logbook shows markers with small orange boxes in the profile
NEW: "Lost Gas" feature allows disabling gases during the dive
CHANGE: Show velocity from 5m/min or more (Ascend or descent)
BUGFIX: Make sure SP1 is always selected on start in Auto-SP mode
CHANGE: New segmented speed graph in divemode
NEW: Safety Stop can be configured (Start-, End- and reset-depth + length of stop) via PC
BUGFIX: minor text allignment in CCR mode
CHANGE: fix timing issues during Bluetooth download (Bluetooth models only)
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =1.92
BUGFIX: Text alignment in logbook
NEW: Show actual dive count in logbook list view (If <1000)
BUGFIX: Minor language and text aligment fixes
BUGFIX: German texts in ppo2 menu were too long for screen resulting in resulting in text display issues
CHANGE: Do not show ppO2 in warning area if already shown in custom view
BUGFIX: Logbook list view for more then 100 stored dives
BUGFIX: BLE timings for MAC issues
BUGFIX: Battery consumption calculation in sleep mode (3,6V battery only)
BUGFIX: +5min for stopwatch during simulation did not work
CHANGE: minor language updates
BUGFIX: Start with Sensor use from sleep (cR only)
CHANGE: Apply button settings when button menu is closed
NEW: Reset button settings on a magnet reset (cR and OSTC 2)
NEW: Additional temperature calibration via PC interface
NEW: Hardware support (Screen)
c) We spend a lot of effort in improving the firmware. Mainly I do the coding for the hwOS and it would be a shame if you don't use it and countless hours of my work were useless. Using the OSTC 2 without PC? Well, ok if you don't need it. But an update from time to time (Let's say every 6 months)? I strongly recommend it...
Kris74
Post by Kris74 »
Perfect, i've done it. All is ok. Finally I'll do it often. Thanks for your answer and your job!
Christophe
