1.1.8 update reports
tanomogi
Post by tanomogi »
1) Still need to reset all settings/reboot firmware/reboot rte few times to successfully load new RTE firmware sections.
- formerly I set it 'custom text' and five gas settings, vpm+2, metric/red view...
- how to perform to section3(RTE part) successfully, following methods this
- still can't upgrade via dctool(win/mac both: hw_ostc3_firmware_readfile4). used companion b8.
2) If reboot RTE, button sensitivity not works well(if 86 show, but really below 50)
Other settings menu values jumps up/down when I scrolling the items. also often stuck in menu cursor when traversing the menus. *actually I think reset settings -> reboot firmware not works.
3) Temperature legend still draws wrong
[img]https://s22.postimg.org/pcemy6mjl/image.jpg[/img]
[img]https://s22.postimg.org/c9j0ewwbl/image.jpg[/img]
[img]https://s22.postimg.org/rwa9saa3l/image.jpg[/img]
[img]https://s22.postimg.org/46ku3lbq9/image.jpg[/img]
[img]https://s22.postimg.org/jgkpas78h/image.jpg[/img]
[img]https://s22.postimg.org/v6yms600x/image.jpg[/img]
[img]https://s22.postimg.org/c1vfbw9wh/image.jpg[/img]
[img]https://s22.postimg.org/ekh4ckvmp/image.jpg[/img]
[img]https://s22.postimg.org/3m5uue71d/image.jpg[/img]
[img]https://s22.postimg.org/5s05owaht/image.jpg[/img]
Re: 1.1.8 update reports
Hello.
Thank you for your feedback. Recalibration of the buttons after RTE update and the RTE update itself will be looked deeper. I will check what makes all the trouble directly on the restart after the RTE update process.
The new temperature scale code does not display 1/10 values but uses them internally. For the smale range you use the scaling routine needs an update.
The best update software (the one I use) is the OSTC Companion and can be found on OSTC_Planner_Webpage free of charge. It works witout any issues. We are using it on many working places at our company. I don't experience any issues with the current beta 8.
Christian
