OSTC4 firmware nightly builds
a nightly build (1.19 beta) is available and included in this post :-)
Please be aware this is a beta version and not intended as firmware for the primary diving computer ´during a dive.
FIX: button sensitivity on startup
NEW: descending & ascending rate in numbers
NEW: possibility of switching off custom views under water
NEW: actual relative reached gradient factor
Looking forward to your comments.
Christian
sniefer
Re: OSTC4 firmware 1.1.9 nightly build available
Post by sniefer »
Hi Christian!
Thank you for the nightly update!
Really like the ascending rates in numbers: now I have an understanding about the graphic icon. I was not sure before what speeds it was indicating :-)
Switching off custom views under water is great! Finally I can switch off the not congruent gas list, forcing me to look inside the menu gas list to check what is active and what not (after making changes to the list under water).
The relative gradient factor also comes in handy..it just doesn't show over 100% if violating a deco obligation. I get the concept of a relative gradient factor, I assume it is directly related to ceiling level calculation.
Anything in the pipeline for an absolute one, too? Like in the 2 series?
Stephan
www.sasnitrox.com
www.sasnitrox.com
Re: OSTC4 firmware nightly builds
a nightly build (1.1.12 beta) is available and included in this post :-)
FIX: temperature graph scaling
NEW: Customview Overview in Dive Mode
Christian
Peter van den Beemt
Post by Peter van den Beemt »
Christian,
large and small temp differences are scaled correct now.
Peter
Peter van den Beemt
OSTC4 - 82
Hi.
Thanks for the feedback.
in todays nightly build (1.1.13 beta with RTE 0.95) included in this post the overview customview labels are fixed and the button sensitivity can now be set to 105% and 110% Please note that after every update the button sensitivity is reset to 80% for usability safety. As always please be aware this is a beta version and not intended as firmware for the primary diving computer ´during a dive.
Christian
Peter van den Beemt
Christian,
I updated my OSTC4.
RTE update failed the first time. Button sensitivity was set to 45 %. Tried Reboot RTE -> no succes. Tried Reboot Firmware -> no succes. After automatic shutdown I tried to update for a second time. This worked. Button sensitivity was set to 50 %. I lost my battery info during this proces...
I noticed that deselecting a view (e.g. Compass) does not remove this view, but just shows a view without content (Not title, no compass). Is this the intended behaviour?
Peter
Peter van den Beemt
OSTC4 - 82
