hwOS Tech: 2.13 released
The new hwOS Tech (for OSTC3, plus, cR and OSTC 2) firmware 2.13 is now available for download:
http://heinrichsweikamp.com/service/firmwares
The firmware itself can be set to English, Deutsch, Italiano and Français. The firmware is now split into two language versions: English + German and French + Italian. Make sure to install the correct HEX file.
Die Firmware selbst kann auf Englisch, Deutsch, Italienisch und Französisch gestellt werden. Die Firmware ist nun auf zwei Versionen geplittet (Englisch + Deutsch sowie Französisch und Italienisch), achtet darauf die richtige HEX Datei zu installieren.
Changes/Änderungen:
[2.13]
BUGFIX: Layout fixes in Gauge mode (German and French language only)
[2.12]
CHANGE: Indicate "Bailout" for bailout deco plan in internal deco planer
CHANGE: Easier to understand "New Battery" menu (OSTC model dependent)
BUGFIX: Minor layout corrections in imperial units dive screen
NEW: New Customview 11 in dive mode shows ppO2, EAD/END and CNS
CHANGE: Customview 4 shows Clock, Battery Information and Tissue Information
CHANGE: Show warnings either in Customview (If active) _or_ next to warning sign
NEW: Show battery type in information menu (T0:3.6V AA, T1:1.5V AA, T2:3.6V/0.8A LiIon, T3:Internal 18650, T4:Internal 16650)
NEW: Show battery type in surface mode next to battery voltage
Details on hwOS: http://heinrichsweikamp.com/hw-os
More details on the new version can be found here: https://www.facebook.com/heinrichsweikamp/
Clownfish
Re: hwOS Tech: 2.12 released
Post by Clownfish »
Took 4 attempts using Subsurface but eventually was able to update.
Michael
Sydney
Australia
OSTC 2 11528
cyberdiamond
Post by cyberdiamond »
I haven't updated yet but it would be clearer again if T2:3.6V/0.8A LiIon was listed as T2:3.7v/0.8A LiIon for the rechargeable LiIon batteries.
OSTC3 #756 / #4491
> batteries.
Good point, yes.
Re: hwOS Tech: 2.13 released
Continue here: read.php?6,17738
