New OSTC4 firmware 1.2.6 and 1.2.7 beta available
Firmware V 1.2.6 stable is available for download from our homepage now: http://heinrichsweikamp.com/service/firmwares
Firmware V 1.2.7 beta is atached to this post
NEW: feet units now everywhere in the displays during the dive
FIX: futureTTS was always calculating 5 minutes independently from settings
FIX: warnings adjusted for ppO2 max and ppO2 min
FIX: text corrections
FIX: button settings internal handling redone (*)
FIX: Desaturation Time and NoFly Time didn't show days.
NEW (V 1.2.7 beta only): Apnea and Gauge mode
You are welcome to test the latest beta and report any feeback here or via email.
with kind regards,
Christian
(*) Please do not downgrade to versions prior to V 1.2.6 after updating to V1.2.6 or later as button sensitivity can be very low after such form of downgrade.
tanomogi
Re: New OSTC4 firmware 1.2.6 and 1.2.7 beta available
Post by tanomogi »
1.2.7b does not show Mon~Sun index mark above the date column.
tanomogi
Post by tanomogi »
I already cleared desaturation time and also cleared 'no fly(24h)' too.
But, If turn it on at cabin(around 800mbar)
* Desaturation notification occured(but did not shows 'no fly')
* Suddenly date to 00.00.00(grayed blink)
See the linked photos below
[img]https://s24.postimg.org/cqcym7lox/0001.jpg[/img]
[img]https://s24.postimg.org/qy78olnrl/0002.jpg[/img]
[img]https://s24.postimg.org/62kydcrkh/0003.jpg[/img]
also already addressed, no Mon~Sun marks in stand-by mode.
Hi.
Thanks for the feedback. Date stuff is fixed already again in the code here.
Desaturation of all 16 tissues, especially the very slow ones, to 777 mbar takes time. In your case 1 day and 15 hours. I can not recommend to turn on the unit during the flight. If switched on it might toogle to dive mode more easily, the flight protection is only active in standby mode.
with kind regards,
Christian
tanomogi
Post by tanomogi »
I Got it! I forgot 'Altitude diving' situation(:D yeah, it must keep track of atmosphere pressures even if below 1013mbars.
thanks Christian.
* No plan to revert OSTC4's compass UI? I like old styled NEWS signs with big UI.
