I've a trouble with the pressure Piezzo button. I haven't been diving this winter and when I get out my OSTC the Left button is hard to use and the right is unresponsive.
With this problem I can just start the Divecomputer but I can't use it. So I can't change the button sensivity. And I can't conncect it to my Macbook to activate the bluetooth.
Do you have a solution for this ?
Christophe
OSTC 2 Unresponsive button
Re: OSTC 2 Unresponsive button
Try soaking it in some warm fresh water for a while. It could be some salt crystals built up
Thanks for your answer i've try but it don't works. I often dive in lake, in fresh water. Just few times in salt water. So I don't think it's the problem.
But thanks for your advice.
Same problem here, right side button unresponsive. Not nice when I couldn't change the fixed set point on it ( a back up computer), while the other one OSTC CR decides to calculate deco on a deep dive with a ppO2 of 0.00 (one cel reading different than the others)
The OSTC2 and OSTC cR buttons can be replaced. Please contact us directly via email to support@heinrichsweikamp.com
