OSTC 2n white screen and cannot connect in Win10 to upgrade firmware?!?
Ostc2NotWorking
Post by Ostc2NotWorking »
(all pictures will be attached)
I am having trouble because my OSTC 2n (barely 1 year old) somehow started showing white screen background on the text.
https://ibb.co/cpaj35
How come? Is it some debug mode?
How can I turn it off?
My firmware version is 2.01.
One solution I wanted to try was upgrading firmware, but I cannot connect to it.
First I tried connecting to it via Companion, when I pick Ostc 2n it cannot connect with COM 3:
https://ibb.co/irYyVk
When I choose Ostc 2 it does connect, but disables the Update Firmware option:
https://ibb.co/kg73wQ
https://ibb.co/dfHaAk
I've even tried uploading firmware without connecting, doesn't work (makes sense, but as nothing else works, tried that as well).
In both options (OSTC 2 or OSTC 2n/...) when I choose COM 4, the program hangs and dies.
Next, off I've tried installing your mentioned drivers for USB:
http://www.ftdichip.com/Drivers/VCP.htm
Still nothing, the same issue.
Next, I've tried installing your Bootloader v2, but it doesn't even see it:
https://ibb.co/fQPSO5
When I switch to COM 4, it hangs again.
I've also tried just uploading firmware option in it, but of course that it doesn't work.
Ok, what do I do? This simply doesn't work.
Thank you!
Re: OSTC 2n white screen and cannot connect in Win10 to upgrade firmware?!?
This is not a 2N. Please check about this issue here: read.php?6,17017,17018
