				During dive "Menu?" activates automatically, seems not normal
				Posted: 03 Aug 2017, 10:27
				by chrisrms
				I noticed that during a dive the "Menu?" (bottom center of the screen with yellow background) does activate automatically several times and disappears again. I think this is not normal. I have the button sensitivity set to 95 %.
				Re: During dive "Menu?" activates automatically, seems not normal
				Posted: 04 Aug 2017, 13:53
				by Claude
				Hi Chrisrms,
Same for me. I put the sensitivity to 75% and no more Problem.
Just try this if needed.
				Posted: 07 Aug 2017, 08:23
				by chrisrms
				Hi Claude,
thanks for feed-back.
I tried with a 90 % setting but then it's hard to change anything during dive, even changing the "View" window content is hard, I have to try several times before anything happens. It does it well though when setting is at 95 %. Hmmmm...
				Posted: 07 Aug 2017, 09:27
				Actually, I've been struggling too using the buttons with thick dry gloves. Pressing the buttons just did not work properly unless I increased the sensitivity. Increasing the sensitivity caused the same problems you have.
Now I found out that if I swipe across the individual buttons (left to right) I can operate them much easier and more accurately at a lower sensitivity. You might want to give that a try under water.
				Posted: 07 Aug 2017, 10:50
				by chrisrms
				I'll try during this weeks dive and send a feed-back.
Thanks for help!
Christoph
