During dive "Menu?" activates automatically, seems not normal
chrisrms
I noticed that during a dive the "Menu?" (bottom center of the screen with yellow background) does activate automatically several times and disappears again. I think this is not normal. I have the button sensitivity set to 95 %.
Claude
Re: During dive "Menu?" activates automatically, seems not normal
Hi Chrisrms,
Same for me. I put the sensitivity to 75% and no more Problem.
Just try this if needed.
Claude
OSCT4 #398
OSCT4 #550
OSTC2C #8058
Claude
OSCT4 #398
OSCT4 #550
OSTC2C #8058
chrisrms
Hi Claude,
thanks for feed-back.
I tried with a 90 % setting but then it's hard to change anything during dive, even changing the "View" window content is hard, I have to try several times before anything happens. It does it well though when setting is at 95 %. Hmmmm...
Actually, I've been struggling too using the buttons with thick dry gloves. Pressing the buttons just did not work properly unless I increased the sensitivity. Increasing the sensitivity caused the same problems you have.
Now I found out that if I swipe across the individual buttons (left to right) I can operate them much easier and more accurately at a lower sensitivity. You might want to give that a try under water.
chrisrms
I'll try during this weeks dive and send a feed-back.
Thanks for help!
Christoph
Thanks for help!
Christoph
