New OSTC4 1.3.5 beta available
Firmware V 1.3.5 beta is atached to this post.
FIX: imperical unit fix in big font mode
NEW: imperical units in gas setup
CHG: date format in logbook pages
CHG: partly new RTE
FIX: safety stop depth view @ 3 mtr setting
FIX: menu headers in dive mode
You are welcome to test the latest beta and report any feeback here or via email.
with kind regards,
Christian
CHG: partly new RTE
with kind regards,
Christian
Re: New OSTC4 1.3.5 beta available
On center 'Overview' mode with VPM,
It does not shows 'current GF' <-- It showed/calculated only in ZH-L16(not enough CPU power for background realtime calculation with both algorithms?)
Hi Christian,
Just tried today. Thanks for the logbook modifications.
I noticied that the buttons sensibility is different. I put 75% instead 90% to have the same result. Any changes ?
Claude
OSCT4 #398
OSCT4 #550
OSTC2C #8058
Claude
OSCT4 #398
OSCT4 #550
OSTC2C #8058
No updates and answer about "Actual GF" not working in VPM mode?(curious about realtime dual algorithms)
Any chance to realease Beta 1.3.5 to production at some stage or another?
Ich ziehe den code im Rahmen der Vorbereitung zur Veröffentlichung gerade auf GCC um. Da hakt es hier und da noch... Daher kann ich keinen Termin versprechen. Wir sind dran.
Any news on 1.3.5 coming out of beta?
Bug Report:
Version: 1.3.5 BETA. 5th dive on version.
On dive in high salinity salt water (Arabian gulf / Persian gulf), the OSTC4 depth gauge kept reading out 6m flat, as well as the timer stuck at 1 min and 1 second. The compass also had a stuck readout and would not change on reorientation.
The buttons were still responsive and the menu was accessible.
On resurface the OSTC 4 switched back to surface mode and the system automatically reset and saved the erroneous dive information. On subsequent dive the OSTC4 was working normally.
Cheers.
Cheers.
Hi there!
The exact same thing happened with my computer! Mine is still running on the 1.3.0 software version. On the decent the readings froze on 9.9 meters along with the compass. The only other thing that was working was the stopwatch.
The buttons were responsive but the readings were frozen for the whole dive until we reached 6.0 meters during the ascent. Then the readings became live again, the computer showed a deco stop but it did not record anything during the dive (depth, temperature, ppO2, etc) except for the time.
Please let us know what caused this problem
Yiannis Panagiotou
OSTC 4 #236
Yiannis Panagiotou
OSTC 4 #236
Hi Yiannis,
From here I'd assume that this is more an hardware issue (e.g. with the pressure sensor) then a software issue. Please get in contact with us: info@heinrichsweikamp.com
> modifications.
Yes, there have been internal changes in the range of the sensitvity.
> modifications.
