Hi,I was in Hemmoor today and made 2 dives in gauge mode.
1 to 33 m and 1 deco to 30.
All went well, but when surfaced and in surfacemode, the ostc went back on a dive to 7.1 m and it stayed there.
Should i upload new firmware, reset only gave this message and now it's not turning on anymore.
Firmware 1.44, i think, or 1.40
Here's the data:
rrAArr. 13 11
128 56 4 64 128
0 0 128 64 0
OSTC back in divemode
Re: OSTC back in divemode
I've uploaded new firmware and it's running again.
I think i'll take my laptop with me next time.
Ivar
Ivar
ok, too soon, it's turned itself off again.
Firmware 1.47 by the way.
I'll try now with stable 1.40
Ivar
Ivar
Hello Thor,
Is the yellow LED blinking after the unit turned itself off? I'm afraid this LED blinks two times every 15s and this is an error code that the connection to the pressure sensor is not working correct. And this means the unit requires some maintenance at our place. In this case, please contact us directly: info@heinrichsweikamp.com - we'll take care of this immediately.
oops i guess, i'm dying here:
on screen:
ppO2: 2.10
cns every 2 second going 1 % up now at over 150
Depth: 99.9, on air
Water temp: -43.6
No stop time: 0
will try to get 1.40 in there
error code after check pic reset:
tAzCBt. 13 10
0 48 4 64 128
0 38 32 64 0
Error code after write flash reset:
tAzCBt. 13 15
0 56 4 64 128
0 38 32 64 0
I think i'll need to get it back to you.
Do you need some field testing with the ostc mk 2?
on screen:
ppO2: 2.10
Depth: 99.9, on air
Water temp: -43.6
No stop time: 0
tAzCBt. 13 10
0 48 4 64 128
0 38 32 64 0
tAzCBt. 13 15
0 56 4 64 128
0 38 32 64 0
Ivar
Ivar
